is a factory for creating a reader proxy based on the filename/extension. More...
#include <vtkSMReaderFactory.h>
| void | Initialize () |
| Cleanup all registered prototypes. More... | |
| void | RegisterPrototype (const char *xmlgroup, const char *xmlname) |
| Register a prototype. More... | |
| bool | CanReadFile (const char *filename, vtkSMSession *session) |
| Returns true if a reader can be determined that can read the file. More... | |
| vtkStringList * | GetPossibleReaders (const char *filename, vtkSMSession *session) |
| Get the list of readers that can possibly read the file. More... | |
| vtkStringList * | GetReaders (vtkSMSession *session) |
| Returns a list of 3-tuples where the 1st string is the group, the 2nd string is the reader name and the 3rd string is the reader description This returns all the possible readers with a given connection id. More... | |
| vtkStringList * | GetReaders (const char *filename, vtkSMSession *session) |
| Returls list of readers that can read the file using its extension and connection id. More... | |
| virtual const char * | GetSupportedFileTypes (vtkSMSession *session) |
| Returns a formatted string with all supported file types. More... | |
| unsigned int | GetNumberOfRegisteredPrototypes () |
| Returns the number of registered prototypes. More... | |
| virtual void | UpdateAvailableReaders () |
| Every time a new proxy definition is added we check to see if it is a reader and then we add it to the list of available readers. More... | |
| virtual char * | GetReaderName () |
| Returns the xml-name for the reader that can read the file queried by the most recent CanReadFile() call. More... | |
| virtual char * | GetReaderGroup () |
| Returns the xml-group for the reader that can read the file queried by the most recent CanReadFile() call. More... | |
| void | AddGroup (const char *groupName) |
| Add/remove a group name to look for readers in. More... | |
| void | RemoveGroup (const char *groupName) |
| void | GetGroups (vtkStringList *groups) |
| static vtkSMReaderFactory * | New () |
| static vtkSMReaderFactory * | SafeDownCast (vtkObject *o) |
| static bool | TestFileReadability (const char *filename, vtkSMSession *session) |
| Helper method to test is a file is readable on the server side. More... | |
| static void | AddReaderToWhitelist (const char *readerxmlgroup, const char *readerxmlname) |
| This function is for ParaView based applications that only wish to expose a subset of the readers. More... | |
| static bool | CanReadFile (const char *filename, vtkSMProxy *reader) |
| Helper method to check if the reader can read the given file. More... | |
| static bool | CanReadFile (const char *filename, const char *readerxmlgroup, const char *readerxmlname, vtkSMSession *session) |
| vtkSMReaderFactory () | |
| ~vtkSMReaderFactory () override | |
| void | RegisterPrototype (const char *xmlgroup, const char *xmlname, const char *extensions, const char *description) |
| virtual void | SetReaderName (const char *) |
| virtual void | SetReaderGroup (const char *) |
| vtkSMObject () | |
Static Protected Member Functions | |
| static bool | GetFilenameIsDirectory (const char *fname, vtkSMSession *session) |
| Returns true if the fname refers to a directory or a link to a directory. More... | |
Protected Attributes | |
| char * | ReaderName |
| char * | ReaderGroup |
| vtkStringList * | Readers |
vtkSMReaderFactory is a factory for creating a reader that reads a particular file. The reader factory needs to be configured to register the reader prototypes supported by the application. This is done automatically when the reader's proxy definition is registered AND if it has the extensions specified in the Hints section of the XML proxy definition. It is done with the following format:
* <ReaderFactory extensions="[list of expected extensions]" * file_description="[description of the file]" /> *
Once the factory has been configured, the API to create readers, get available readers etc. can be used.
Definition at line 46 of file vtkSMReaderFactory.h.
Definition at line 50 of file vtkSMReaderFactory.h.
| void vtkSMReaderFactory::Initialize | ( | ) |
If it is already registered this becomes a no-op.
| bool vtkSMReaderFactory::CanReadFile | ( | const char * | filename, |
| vtkSMSession * | session | ||
When this returns true, one can use GetReaderGroup() and GetReaderName() to obtain the xmlgroup and xmlname for the reader that can read the file. When this returns false, use GetPossibleReaders() to get the list of readers that can possibly read the file.
This is valid only if CanReadFile() returned true.
| vtkStringList* vtkSMReaderFactory::GetPossibleReaders | ( | const char * | filename, |
This is used when the factory cannot determine which reader to use for reading the file. The user can then choose from the provided options. Returns a list of 3-tuples where the 1st string is the group, the 2nd string is the reader name and the 3rd string is the reader description Note that the extension test is skipped in this case.
| vtkStringList* vtkSMReaderFactory::GetReaders | ( | vtkSMSession * | session | ) |
| vtkStringList* vtkSMReaderFactory::GetReaders | ( | const char * | filename, |
This has nothing to do with the whether the file is readable by a reader, just test the file permissions etc. Internally uses the ServerFileListing proxy.
cid is not used currently. An example returned string would look like:
* "Supported Files (*.vtk *.pvd);;PVD Files (*.pvd);;VTK Files (*.vtk)" *
This is a generic method that simply tries to call CanReadFile() on the reader. If the reader des not support CanReadFile() then we assume the reader can read the file, and return true.
| unsigned int vtkSMReaderFactory::GetNumberOfRegisteredPrototypes | ( | ) |
| void vtkSMReaderFactory::AddGroup | ( | const char * | groupName | ) |
By default "source" is included.
| void vtkSMReaderFactory::RemoveGroup | ( | const char * | groupName | ) |
| void vtkSMReaderFactory::GetGroups | ( | vtkStringList * | groups | ) |
If this function is never called, the reader factory will expose all the readers as it has in the past. However, if any readers are specified by passing their group name and reader name to this function, then only those readers will be available in any reader factories created by the application. This is intended to be called at the beginning of the application's execution before any sessions are created.
staticprotected |
protectedvirtual |
protectedvirtual |
Definition at line 191 of file vtkSMReaderFactory.h.
Definition at line 194 of file vtkSMReaderFactory.h.
Definition at line 195 of file vtkSMReaderFactory.h.
