manages ParaView plugins. More...
#include <vtkSMPluginManager.h>
| enum | { PluginLoadedEvent = 100000, LocalPluginLoadedEvent, RemotePluginLoadedEvent } |
| void | LoadPluginConfigurationXMLFromString (const char *xmlcontents, vtkSMSession *session, bool remote) |
| Plugin configuration XML is a simple XML that makes ParaView aware of the plugins available and may result in loading of those plugins that are marked for auto-loading. More... | |
| void | RegisterSession (vtkSMSession *) |
| Register/Unregister a session. More... | |
| void | UnRegisterSession (vtkSMSession *) |
| virtual vtkPVPluginsInformation * | GetLocalInformation () |
| vtkPVPluginsInformation provides information about plugins loaded/available. More... | |
| vtkPVPluginsInformation * | GetRemoteInformation (vtkSMSession *) |
| const char * | GetLocalPluginSearchPaths () |
| Returns the plugin search paths used either locally or remotely. More... | |
| const char * | GetRemotePluginSearchPaths (vtkSMSession *) |
| bool | LoadRemotePlugin (const char *filename, vtkSMSession *) |
| Loads the plugin either locally or remotely. More... | |
| bool | LoadLocalPlugin (const char *filename) |
| static vtkSMPluginManager * | New () |
| static vtkSMPluginManager * | SafeDownCast (vtkObject *o) |
| vtkSMPluginManager () | |
| ~vtkSMPluginManager () override | |
| void | OnPluginRegistered () |
| void | OnPluginAvailable () |
| void | UpdateLocalPluginInformation () |
| vtkSMObject () | |
Protected Attributes | |
| bool | InLoadPlugin |
| vtkPVPluginsInformation * | LocalInformation |
vtkSMPluginManager is used to load plugins as well as discover information about currently loaded and available plugins.
vtkSMPluginManager supports multiple sessions. Every vtkSMSession registers itself with the vtkSMPluginManager during initialization.
Definition at line 35 of file vtkSMPluginManager.h.
Definition at line 39 of file vtkSMPluginManager.h.
| anonymous enum |
| Enumerator | |
| PluginLoadedEvent | |
| LocalPluginLoadedEvent | |
| RemotePluginLoadedEvent | |
Definition at line 97 of file vtkSMPluginManager.h.
| void vtkSMPluginManager::RegisterSession | ( | vtkSMSession * | ) |
Every vtkSMSession must be registered with the vtkSMPluginManager. This is done automatically by vtkSMSession during the initialization stage. Note that the vtkSMSession is not reference counted.
| void vtkSMPluginManager::UnRegisterSession | ( | vtkSMSession * | ) |
LocalInformation corresponds to plugins loaded on the local process. For remote sessions i.e. those that connect to a remote server process, one can use GetRemoteInformation() to access information about plugins on the remote process.
| vtkPVPluginsInformation* vtkSMPluginManager::GetRemoteInformation | ( | vtkSMSession * | ) |
| const char* vtkSMPluginManager::GetLocalPluginSearchPaths | ( | ) |
For non-remote sessions, GetRemotePluginSearchPaths() returns the same value as GetLocalPluginSearchPaths().
| const char* vtkSMPluginManager::GetRemotePluginSearchPaths | ( | vtkSMSession * | ) |
| bool vtkSMPluginManager::LoadRemotePlugin | ( | const char * | filename, |
| vtkSMSession * | |||
| bool vtkSMPluginManager::LoadLocalPlugin | ( | const char * | filename | ) |
| void vtkSMPluginManager::LoadPluginConfigurationXMLFromString | ( | const char * | xmlcontents, |
| vtkSMSession * | session, | ||
| bool | remote | ||
In ParaView application there are two uses for this:
This method loads the plugin configuration xml either on the local process or the remote server process(es). session is only used when remote==true and session itself is a remote session.
Definition at line 108 of file vtkSMPluginManager.h.
Definition at line 113 of file vtkSMPluginManager.h.
