| const char * | GetPluginStatusMessage (unsigned int) |
| | Note that unlike other properties, this one is updated as a consequence of calling PluginRequirementsSatisfied(). More...
| void | SetAutoLoad (unsigned int cc, bool) |
| | API to change auto-load status. More...
| void | SetAutoLoadAndForce (unsigned int cc, bool) |
| | This is a hack. More...
| void | CopyFromObject (vtkObject *) override |
| | Transfer information about a single object into this object. More...
| void | AddInformation (vtkPVInformation *) override |
| | Merge another information object. More...
| void | Update (vtkPVPluginsInformation *other) |
| | Updates the local information with elements from other without overriding auto-load state. More...
| unsigned int | GetNumberOfPlugins () |
| | API to iterate over the information collected for each plugin. More...
| const char * | GetPluginName (unsigned int) |
| const char * | GetPluginFileName (unsigned int) |
| const char * | GetPluginVersion (unsigned int) |
| bool | GetPluginLoaded (unsigned int) |
| const char * | GetRequiredPlugins (unsigned int) |
| bool | GetRequiredOnServer (unsigned int) |
| bool | GetRequiredOnClient (unsigned int) |
| const char * | GetDescription (unsigned int) |
| bool | GetAutoLoad (unsigned int) |
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual char * | GetSearchPaths () |
| | Get the plugin search path. More...
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
information about plugins tracked by vtkPVPluginTracker.
vtkPVPluginsInformation is used to collect information about plugins tracked by vtkPVPluginTracker.
Definition at line 30 of file vtkPVPluginsInformation.h.
