| int | IsInDomain (vtkSMProperty *property) override |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMMultiplexerInputDomain () |
| | ~vtkSMMultiplexerInputDomain () |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
input domain used for vtkSMMultiplexerSourceProxy
vtkSMMultiplexerInputDomain is intended to be used for input properties on vtkSMMultiplexerSourceProxy. It ensures that IsInDomain checks are forwarded for all available multiplexed proxies.
Definition at line 30 of file vtkSMMultiplexerInputDomain.h.
