| virtual void | Update (vtkSMProperty *) override |
| | Overridden to get list of materials from materiallibrary singleton. More...
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMMaterialDomain () |
| | ~vtkSMMaterialDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | CallMeSometime () |
Protected Member Functions inherited from vtkSMStringListDomain |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
Manages the list of OSPRay materials choosable to draw with.
This class is a link between the global MaterialLibrary and the choices available on the display section of the Property Panel. When ParaView has no materials loaded, the list is simply "None" and not useable. When materials are loaded, the list lets the user pick None, any one for whole actor colors, or 'Value Indexed' which says that each block and cell gets to make its own choice via the indexed lookup table annotation names.
Definition at line 36 of file vtkSMMaterialDomain.h.
