| | Update self based on the "unchecked" values of all required properties. More...
| virtual std::string | GetFileName () |
| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | This method is over-written to automatically update the default filename at run time. More...
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| | Update self checking the "unchecked" values of all required properties. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMInputFileNameDomain () |
| | ~vtkSMInputFileNameDomain () override |
Protected Member Functions inherited from vtkSMStringListDomain |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
a string domain that can be set automatically with the source file name
vtkSMInputFileNameDomain does not really restrict the values of the property that contains it. All string values are valid. Rather, it is used to annotate a pipeline with the source name. This domain works with only vtkSMStringVectorProperty.
- See also
- vtkSMDomain vtkSMStringVectorProperty
Definition at line 34 of file vtkSMInputFileNameDomain.h.
