| int | IsInDomain (vtkSMProperty *property) override |
| int | SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override |
| vtkSMProperty * | GetInfoProperty () |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMIndexSelectionDomain () |
| | ~vtkSMIndexSelectionDomain () override |
| | vtkSMDomain () |
| virtual int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
Select names from an indexed string list.
See the vtkMPASReader proxy in readers.xml for how the properties should be set up for this domain.
Definition at line 30 of file vtkSMIndexSelectionDomain.h.
