| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More...
| void | Update (vtkSMProperty *property) override |
| | Updates the available field data based on the input dataset type, if possible. More...
Public Member Functions inherited from vtkSMEnumerationDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (int val, unsigned int &idx) |
| | Returns true if the int is in the domain. More...
| unsigned int | GetNumberOfEntries () |
| | Returns the number of entries in the enumeration. More...
| int | GetEntryValue (unsigned int idx) |
| | Returns the integer value of an enumeration entry. More...
| const char * | GetEntryText (unsigned int idx) |
| | Returns the descriptive string of an enumeration entry. More...
| const char * | GetEntryTextForValue (int value) |
| | Returns the text for an enumeration value. More...
| int | HasEntryText (const char *text) |
| | Return 1 is the text is present in the enumeration, otherwise 0. More...
| int | GetEntryValueForText (const char *text) |
| | Get the value for an enumeration text. More...
| int | GetEntryValue (const char *text, int &valid) |
| | Given an entry text, return the integer value. More...
| const char * | GetInfoText (unsigned int idx) |
| | Returns the info text for an enumeration entry. More...
| void | AddEntry (const char *text, int value, const char *info=nullptr) |
| | Add a new enumeration entry. More...
| void | RemoveAllEntries () |
| | Clear all entries. More...
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMFieldDataDomain () |
| | ~vtkSMFieldDataDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *elem) override |
Protected Member Functions inherited from vtkSMEnumerationDomain |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| | vtkSMEnumerationDomain () |
| | ~vtkSMEnumerationDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
enumeration domain to select array association or attribute type.
vtkSMFieldDataDomain can be used on a vtkSMIntVectorProperty that is intended to specify the attribute type (vtkDataObject::AttributeTypes) or field association (vtkDataObject::FieldAssociations).
By default, vtkDataObject::Field (or vtkDataObject::FIELD_ASSOCIATION_NONE) is not added to the domain. If you want to support field data, then use enable_field_data="1" attribute in the XML configuration.
Selecting the default value
vtkSMFieldDataDomain picks the default value to be the first attribute type that has non empty arrays and non-zero tuples. If all attributes have no tuples, then the first attribute with non empty arrays is selected. If all attributes have no arrays, then vtkSMEnumerationDomain picks the default. For this to work, the domain must be provided an Input property as a required property for function "Input".
Deprecated Usage
Previously (5.6 and earlier), vtkSMFieldDataDomain was added to vtkSMStringVectorProperty instances that allowed user to choose the array to process. This is no longer needed or supported. Simply remove the vtkSMFieldDataDomain from the XML for such properties.
The domain provided ability to limit the attribute types to the data type of the input dataset. This was clumsy since it did not correctly handle cases where data type changes or non empty attribute types changed. Hence we've dropped support for that. Simply remove disable_update_domain_entries and force_point_cell_data attributes from the XML for this domain since they are no longer supported.
Definition at line 57 of file vtkSMFieldDataDomain.h.
