collection of utilities. More...
#include <vtkSMCoreUtilities.h>
| static vtkSMCoreUtilities * | New () |
| static vtkSMCoreUtilities * | SafeDownCast (vtkObject *o) |
| static const char * | GetFileNameProperty (vtkSMProxy *) |
| Given a proxy (or proxy prototype), returns the name of the property that ParaView application will be use as the default FileName property. More... | |
| static std::string | SanitizeName (const char *) |
| Sanitize a label/name to be remove spaces, delimiters etc. More... | |
| static const char * | GetStringForCellType (int cellType) |
| Given a VTK cell type value from the enum in vtkCellTypes.h, returns a string describing that cell type for use if ParaView's GUI. More... | |
| static bool | AdjustRangeForLog (double range[2]) |
| Given a range, converts it to be a valid range to switch to log space. More... | |
| static bool | AdjustRangeForLog (double &rmin, double &rmax) |
| static bool | AdjustRange (double range[2]) |
| Adjust the given range to make it suitable for use with color maps. More... | |
| static bool | AdjustRange (double &rmin, double &rmax) |
| static bool | AlmostEqual (const double range[2], int ulpsDiff) |
Compares val1 and val2 and returns true is the two numbers are within ulpsDiff ULPs (units in last place) from each other. More... | |
| static bool | AlmostEqual (double rmin, double rmax, int ulpsDiff) |
| static const char * | GetInputPropertyName (vtkSMProxy *proxy, int port=0) |
| Given a proxy and a port number get the name of the input. More... | |
| vtkSMCoreUtilities () | |
| ~vtkSMCoreUtilities () override | |
vtkSMCoreUtilities provides miscellaneous utility functions.
Definition at line 32 of file vtkSMCoreUtilities.h.
Definition at line 36 of file vtkSMCoreUtilities.h.
Returns the name of the property or NULL when no such property is found.
If the range is changed, returns true, otherwise returns false.
Definition at line 57 of file vtkSMCoreUtilities.h.
The current logic (which may change in future) does the following:
false and keeps the range unchanged.true if the range was changed, false is the range was left unchanged. Adjust the given range to make it suitable for use with color maps.
false and keeps the range unchanged.true if the range was changed, false is the range was left unchanged. Definition at line 83 of file vtkSMCoreUtilities.h.
Definition at line 99 of file vtkSMCoreUtilities.h.
For example it pasesd VTK_TRIANGLE it will return "Triangle". If an unknown cell type is passed to this it returns the string "Unknown".
