| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| | Since this domain relies on an information only property to get the default status, we override this method to copy the values the info property as the default array selection. More...
Public Member Functions inherited from vtkSMStringListDomain |
| int | IsInDomain (vtkSMProperty *property) override |
| | Returns true if the value of the property is in the domain. More...
| int | IsInDomain (const char *string, unsigned int &idx) |
| | Returns true if the string is in the domain. More...
| const char * | GetString (unsigned int idx) |
| | Returns a string in the domain. More...
| unsigned int | GetNumberOfStrings () |
| | Returns the number of strings in the domain. More...
| | Update self checking the "unchecked" values of all required properties. More...
| void | SetAnimationValue (vtkSMProperty *, int, double) override |
| virtual char * | GetNoneString () |
| | Return the string that is used as "none_string" in XML configuration. More...
| virtual void | SetNoneString (const char *) |
| | Helper method to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| | vtkSMArraySelectionDomain () |
| | ~vtkSMArraySelectionDomain () override |
Protected Member Functions inherited from vtkSMStringListDomain |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | ChildSaveState (vtkPVXMLElement *domainElement) override |
| virtual void | SetStrings (const std::vector< std::string > &strings) |
| | Call to set the strings. More...
| const std::vector< std::string > & | GetStrings () |
| | vtkSMStringListDomain () |
| | ~vtkSMStringListDomain () override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
used on properties that allow users to select arrays.
vtkSMArraySelectionDomain is a domain that can be for used for properties that allow users to set selection-statuses for multiple arrays (or similar items). This is similar to vtkSMArrayListDomain, the only different is that vtkSMArrayListDomain is designed to work with data-information obtained from the required Input property, while vtkSMArraySelectionDomain depends on a required information-only property ("ArrayList") that provides the arrays available.
Supported Required-Property functions:
ArrayList : points a string-vector property that produces the (array_name, status) tuples. This is typically an information-only property.
Definition at line 39 of file vtkSMArraySelectionDomain.h.
