| virtual vtkSMProxy * | GetViewModule () |
| void | SetViewModule (vtkSMProxy *) |
| virtual void | SetAnimationScene (vtkSMProxy *) |
| | Convenience method to set the proxy. More...
| bool | Save () |
| | Begin the saving. More...
| virtual void | SetAnimationScene (vtkSMAnimationScene *) |
| | Get/Set the animation scene that this writer will write. More...
| virtual vtkSMAnimationScene * | GetAnimationScene () |
| virtual void | SetFileName (const char *) |
| | Get/Set the filename. More...
| virtual char * | GetFileName () |
| virtual void | SetStartFileCount (int) |
| | Get/Set the start file count. More...
| virtual int | GetStartFileCount () |
| virtual void | SetPlaybackTimeWindow (double, double) |
| | Get/Set time window that we want to write If PlaybackTimeWindow[0] > PlaybackTimeWindow[1] that mean that we want to export the full time range available. More...
| void | SetPlaybackTimeWindow (double [2]) |
| virtual double * | GetPlaybackTimeWindow () |
| virtual void | GetPlaybackTimeWindow (double &, double &) |
| virtual void | GetPlaybackTimeWindow (double [2]) |
helper class to write animation geometry in a data file.
vtkSMAnimationSceneGeometryWriter is a concrete implementation of vtkSMAnimationSceneWriter that can write the geometry as a data file. This writer can only write the visible geometry in one view.
Definition at line 33 of file vtkSMAnimationSceneGeometryWriter.h.
