| virtual int | GetPortIndex () |
| | Controls which input port this property uses when making connections. More...
| virtual bool | GetNullOnEmpty () |
| | Command that can be used to remove inputs. More...
| virtual char * | GetRemoveCommand () |
| | Remove command is the command called to remove the VTK object on the server-side. More...
| | The name assigned by the xml parser. More...
| | The command name used to set the value on the server object. More...
| | Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
| | If repeatable, a property can have 1 or more values of the same kind. More...
| | This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
| | vtkSIXMLAnimationWriterRepresentationProperty () |
| | ~vtkSIXMLAnimationWriterRepresentationProperty () override |
| bool | Push (vtkSMMessage *, int) override |
| | Overridden to call AddRepresentation on the vtkXMLPVAnimationWriter instance with correct API. More...
| | vtkSIInputProperty () |
| | ~vtkSIInputProperty () override |
| | Push a new state to the underneath implementation. More...
| bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
| | Parse the xml for the property. More...
| virtual void | SetPortIndex (int) |
| | vtkSIProxyProperty () |
| | ~vtkSIProxyProperty () override |
| virtual void | SetNullOnEmpty (bool) |
| vtkObjectBase * | GetObjectBase (vtkTypeUInt32 globalId) |
| bool | IsValidNull (vtkTypeUInt32 globalId) |
| virtual void | SetRemoveCommand (const char *) |
| | vtkSIProperty () |
| | ~vtkSIProperty () override |
| | Convenience method to obtain a vtkSIObject subclass given its global id. More...
| virtual bool | Pull (vtkSMMessage *) |
| | Pull the current state of the underneath implementation. More...
| | Interprets the message. More...
| | vtkObject () |
| | vtkObjectBase () |
vtkSIXMLAnimationWriterRepresentationProperty extends vtkSIInputProperty to add push-API specific to vtkXMLPVAnimationWriter to add representations while assigning them unique names consistently across all processes.
Definition at line 29 of file vtkSIXMLAnimationWriterRepresentationProperty.h.
