| virtual bool | GetArgumentIsArray () |
| | If ArgumentIsArray is true, multiple elements are passed in as array arguments. More...
| | If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values. More...
| virtual bool | GetUseIndex () |
| | If UseIndex and RepeatCommand are true, the property will add an index integer before each command. More...
| | Command that can be used to remove all values. More...
| | If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter. More...
| | The name assigned by the xml parser. More...
| | The command name used to set the value on the server object. More...
| | Is InformationOnly is set to true, this property is used to get information from server instead of setting values. More...
| | If repeatable, a property can have 1 or more values of the same kind. More...
| | This ivar is configured when the xml file is read and is mainly useful to trigger a method call. More...
template<class T, class force_idtype = int>
class vtkSIVectorPropertyTemplate< T, force_idtype >
Definition at line 28 of file vtkSIVectorPropertyTemplate.h.
template<class T , class force_idtype = int>
For example, For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo array(1, 2)
* * Invoke obj SetFoo array(3, 4)
* * Invoke obj SetFoo array(5, 6)
