Abstract class for SIProperty that hold an array of values. More...
#include <vtkSIVectorProperty.h>
| virtual bool | GetUseIndex () |
| static vtkSIVectorProperty * | SafeDownCast (vtkObject *o) |
| vtkSIVectorProperty () | |
| ~vtkSIVectorProperty () override | |
| bool | ReadXMLAttributes (vtkSIProxy *proxyhelper, vtkPVXMLElement *element) override |
| vtkSIProperty () | |
| virtual bool | Push (vtkSMMessage *, int) |
| virtual bool | Pull (vtkSMMessage *) |
Protected Attributes | |
| char * | SetNumberCommand |
| char * | CleanCommand |
| bool | UseIndex |
| int | NumberOfElementsPerCommand |
| char * | InitialString |
| char * | XMLName |
| char * | Command |
| bool | InformationOnly |
| bool | Repeatable |
| bool | IsInternal |
Define the array management API
Definition at line 28 of file vtkSIVectorProperty.h.
Definition at line 31 of file vtkSIVectorProperty.h.
Reimplemented in vtkSIDoubleVectorProperty, vtkSIIdTypeVectorProperty, vtkSIIntVectorProperty, and vtkSIStringVectorProperty.
Reimplemented in vtkSIVectorPropertyTemplate< T, force_idtype >.
If RepeatCommand is true, the command is invoked multiple times, each time with NumberOfElementsPerCommand values.
For example, if RepeatCommand is true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 1 2 3 4 5 6, the resulting stream will have:
* * Invoke obj SetFoo 1 2 * * Invoke obj SetFoo 3 4 * * Invoke obj SetFoo 5 6 *
If UseIndex and RepeatCommand are true, the property will add an index integer before each command.
For example, if UseIndex and RepeatCommand are true, NumberOfElementsPerCommand is 2, the command is SetFoo and the values are 5 6 7 8 9 10, the resulting stream will have:
* * Invoke obj SetFoo 0 5 6 * * Invoke obj SetFoo 1 7 8 * * Invoke obj SetFoo 2 9 10 *
Command that can be used to remove all values.
Typically used when RepeatCommand = 1. If set, the clean command is called before the main Command.
If SetNumberCommand is set, it is called before Command with the number of arguments as the parameter.
protectedvirtual |
protectedvirtual |
protectedvirtual |
overrideprotectedvirtual |
Definition at line 90 of file vtkSIVectorProperty.h.
Definition at line 93 of file vtkSIVectorProperty.h.
Definition at line 94 of file vtkSIVectorProperty.h.
Definition at line 95 of file vtkSIVectorProperty.h.
Definition at line 96 of file vtkSIVectorProperty.h.
