| virtual int | GetNumberOfTimeSteps () |
| double | GetTimeStep (int index) |
| virtual bool | GetTimeRangeValid () |
| virtual double * | GetTimeRange () |
| virtual void | GetTimeRange (double &, double &) |
| virtual void | GetTimeRange (double [2]) |
| virtual vtkDataObject * | GetCurrentInputDataObject () |
| void | SetComputedAnnotationValue (const char *value) |
| virtual void | SetExpression (const char *) |
| | Set the expression to evaluate. More...
| virtual char * | GetExpression () |
| virtual void | SetArrayAssociation (int) |
| | Set the input array association. More...
| virtual int | GetArrayAssociation () |
| virtual char * | GetComputedAnnotationValue () |
| | Get the value that is going to be printed to the output. More...
| virtual bool | GetDataTimeValid () |
| | Get methods for use in annotation.py. More...
| virtual double | GetDataTime () |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPythonAnnotationFilter () |
| | ~vtkPythonAnnotationFilter () override |
| virtual void | EvaluateExpression () |
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
filter used to generate text annotation from Python expressions.
vtkPythonAnnotationFilter is designed to generate vtkTableAlgorithm with a single string in it. The goal is that user will write a Python expression, similar to an expression in Python Calculator (vtkPythonCalculator). The generated result is converted to string and placed in the output.
The variables available in the expression evaluation scope are as follows:
- sanitized array names for all arrays in the chosen ArrayAssociation.
- input: refers to the input dataset (wrapped as vtk.numpy_interface.dataset_adapter.DataObject or subclass).
- time_value: vtkDataObject::DATA_TIME_STEP() from input.
- time_steps: vtkDataObject::TIME_STEPS() from the input, if any
- time_range: vtkDataObject::TIME_RANGE() from the input, if any
Examples of valid expressions are:
Definition at line 43 of file vtkPythonAnnotationFilter.h.
