| virtual void | SetArrayAssociation (int) |
| | Which field data to get the arrays from. More...
| virtual int | GetArrayAssociation () |
| virtual void | SetExpression (const char *) |
| | Set the text of the python expression to execute. More...
| virtual char * | GetExpression () |
| virtual void | SetArrayName (const char *) |
| | Set the name of the output array. More...
| virtual char * | GetArrayName () |
| vtkProgrammableFilter * | NewInstance () const |
| void | SetExecuteMethod (void(*f)(void *), void *arg) |
| void | SetExecuteMethodArgDelete (void(*f)(void *)) |
| vtkPolyData * | GetPolyDataInput () |
| vtkStructuredPoints * | GetStructuredPointsInput () |
| vtkStructuredGrid * | GetStructuredGridInput () |
| vtkUnstructuredGrid * | GetUnstructuredGridInput () |
| vtkRectilinearGrid * | GetRectilinearGridInput () |
| vtkGraph * | GetGraphInput () |
| vtkTable * | GetTableInput () |
| virtual void | SetCopyArrays (bool) |
| virtual bool | GetCopyArrays () |
| virtual void | CopyArraysOn () |
| virtual void | CopyArraysOff () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPythonCalculator () |
| | ~vtkPythonCalculator () override |
| void | Exec (const char *) |
| | For internal use only. More...
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| int | RequestDataObject (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | vtkProgrammableFilter () |
| | ~vtkProgrammableFilter () |
| int | RequestData (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| virtual int | RequestUpdateTime (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Evaluates a Python expression vtkPythonCalculator uses Python to calculate an expression.
This filter depends heavily on the numpy and paraview.vtk modules. To use the parallel functions, mpi4py is also necessary. The expression is evaluated and the resulting scalar value or numpy array is added to the output as an array. See numpy and paraview.vtk documentation for the list of available functions.
This filter tries to make it easy for the user to write expressions by defining certain variables. The filter tries to assign each array to a variable of the same name. If the name of the array is not a valid Python variable, it has to be accessed through a dictionary called arrays (i.e. arrays['array_name']). The points can be accessed using the points variable.
Definition at line 39 of file vtkPythonCalculator.h.
