#include <vtkParticlePipeline.h>
| typedef vtkCPPipeline | Superclass |
Public Types inherited from vtkCPPipeline | |
| void | PrintSelf (ostream &os, vtkIndent indent) |
| virtual int | RequestDataDescription (vtkCPDataDescription *desc) |
| Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More... | |
| virtual int | CoProcess (vtkCPDataDescription *desc) |
| Execute the pipeline. Returns 1 for success and 0 for failure. More... | |
| virtual void | SetFilename (const char *) |
| virtual char * | GetFilename () |
| virtual void | SetParticleRadius (double) |
| virtual double | GetParticleRadius () |
| virtual void | SetCameraThetaAngle (double) |
| virtual double | GetCameraThetaAngle () |
| virtual void | SetCameraPhiAngle (double) |
| virtual double | GetCameraPhiAngle () |
| virtual void | SetCameraDistance (double) |
| virtual double | GetCameraDistance () |
| virtual void | SetBounds (double, double, double, double, double, double) |
| virtual void | SetBounds (double [6]) |
| virtual double * | GetBounds () |
| virtual void | GetBounds (double data[6]) |
| virtual void | SetAttributeMaximum (double) |
| virtual double | GetAttributeMaximum () |
| virtual void | SetAttributeMinimum (double) |
| virtual double | GetAttributeMinimum () |
Public Member Functions inherited from vtkCPPipeline | |
| virtual int | Finalize () |
| Finalize the pipeline before deleting it. More... | |
| static vtkParticlePipeline * | New () |
| static vtkParticlePipeline * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkCPPipeline | |
| static vtkCPPipeline * | SafeDownCast (vtkObject *o) |
| vtkParticlePipeline () | |
| virtual | ~vtkParticlePipeline () |
| void | SetupPipeline () |
Protected Member Functions inherited from vtkCPPipeline | |
| vtkCPPipeline () | |
| virtual | ~vtkCPPipeline () |
Protected Attributes | |
| char * | Filename |
| double | ParticleRadius |
| double | CameraThetaAngle |
| double | CameraPhiAngle |
| double | CameraDistance |
| double | Bounds [6] |
| double | AttributeMaximum |
| double | AttributeMinimum |
| vtkTrivialProducer * | input |
| vtkColorTransferFunction * | lut |
| vtkSphereSource * | sphere |
| vtkOutlineSource * | outline |
| vtkGlyph3DMapper * | particleMapper |
| vtkPolyDataMapper * | outlineMapper |
| vtkActor * | particleActor |
| vtkActor * | outlineActor |
| vtkLightKit * | lightKit |
| vtkIceTSynchronizedRenderers * | syncRen |
| vtkSynchronizedRenderWindows * | syncWin |
| vtkRenderWindow * | window |
| vtkRenderer * | renderer |
| vtkWindowToImageFilter * | w2i |
| vtkPNGWriter * | writer |
Definition at line 37 of file vtkParticlePipeline.h.
Definition at line 41 of file vtkParticlePipeline.h.
protectedvirtual |
Reimplemented from vtkCPPipeline.
If coprocessing does need to be performed this time step it fills in the FieldNames array that the coprocessor requires in order to fulfill all the coprocessing requests for this TimeStep/Time combination.
Implements vtkCPPipeline.
Definition at line 93 of file vtkParticlePipeline.h.
Definition at line 95 of file vtkParticlePipeline.h.
Definition at line 97 of file vtkParticlePipeline.h.
Definition at line 98 of file vtkParticlePipeline.h.
Definition at line 99 of file vtkParticlePipeline.h.
Definition at line 101 of file vtkParticlePipeline.h.
Definition at line 103 of file vtkParticlePipeline.h.
Definition at line 104 of file vtkParticlePipeline.h.
Definition at line 106 of file vtkParticlePipeline.h.
Definition at line 107 of file vtkParticlePipeline.h.
Definition at line 108 of file vtkParticlePipeline.h.
Definition at line 109 of file vtkParticlePipeline.h.
Definition at line 110 of file vtkParticlePipeline.h.
Definition at line 111 of file vtkParticlePipeline.h.
Definition at line 112 of file vtkParticlePipeline.h.
Definition at line 113 of file vtkParticlePipeline.h.
Definition at line 114 of file vtkParticlePipeline.h.
Definition at line 115 of file vtkParticlePipeline.h.
Definition at line 116 of file vtkParticlePipeline.h.
Definition at line 117 of file vtkParticlePipeline.h.
Definition at line 118 of file vtkParticlePipeline.h.
Definition at line 119 of file vtkParticlePipeline.h.
Definition at line 120 of file vtkParticlePipeline.h.
