| vtkMTimeType | GetMTime () override |
| | Return the MTime also considering the internal writer. More...
| int | Write () |
| | Invoke the writer. More...
| void | SetInterpreter (vtkClientServerInterpreter *interp) |
| | Get/Set the interpreter to use to call methods on the writer. More...
| void | SetWriter (vtkAlgorithm *) |
| | Set/get the internal writer. More...
| virtual vtkAlgorithm * | GetWriter () |
| virtual void | SetFileNameMethod (const char *) |
| | Name of the method used to set the file name of the internal writer. More...
| virtual char * | GetFileNameMethod () |
| virtual void | SetFileName (const char *) |
| | Get/Set the name of the output file. More...
| virtual char * | GetFileName () |
| virtual int | GetPiece () |
| | Get/Set the piece number to write. More...
| virtual void | SetPiece (int) |
| virtual int | GetNumberOfPieces () |
| | Get/Set the number of pieces into which the inputs are split. More...
| virtual void | SetNumberOfPieces (int) |
| virtual int | GetGhostLevel () |
| | Get/Set the number of ghost levels to be written. More...
| virtual void | SetGhostLevel (int) |
| void | SetPreGatherHelper (vtkAlgorithm *) |
| | Get/Set the pre-reduction helper. More...
| virtual vtkAlgorithm * | GetPreGatherHelper () |
| void | SetPostGatherHelper (vtkAlgorithm *) |
| | Get/Set the reduction helper. More...
| virtual vtkAlgorithm * | GetPostGatherHelper () |
| virtual int | GetWriteAllTimeSteps () |
| | Must be set to true to write all timesteps, otherwise only the current timestep will be written out. More...
| virtual void | SetWriteAllTimeSteps (int) |
| virtual void | WriteAllTimeStepsOn () |
| virtual void | WriteAllTimeStepsOff () |
| virtual char * | GetFileNameSuffix () |
| | Provides an option to pad the time step when writing out time series data. More...
| virtual void | SetFileNameSuffix (const char *) |
| virtual void | SetNumberOfIORanks (int) |
| | In parallel runs, this writer can consolidate output from multiple ranks to a subset of ranks. More...
| virtual int | GetNumberOfIORanks () |
| virtual void | SetRankAssignmentMode (int) |
| | When NumberOfIORanks is greater than 1 and less than the number of MPI ranks, this controls how the ranks that write to disk are determined. More...
| virtual int | GetRankAssignmentMode () |
| void | SetController (vtkMultiProcessController *controller) |
| | Get/Set the controller to use. More...
| virtual vtkMultiProcessController * | GetController () |
| vtkDataObjectAlgorithm * | NewInstance () const |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkParallelSerialWriter () |
| | ~vtkParallelSerialWriter () override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | vtkDataObjectAlgorithm () |
| | ~vtkDataObjectAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
parallel meta-writer for serial formats
vtkParallelSerialWriter is a meta-writer that enables serial writers to work in parallel. By default, it gathers data to the 1st node (root node) and invokes the internal writer. The reduction is controlled by the PreGatherHelper and PostGatherHelper. Instead of collecting all the data to the root node the filter supports reducing down to a target number of ranks which ranks chosen in either round-robin or contiguous fashion.
This also makes it possible to write time-series for temporal datasets using simple non-time-aware writers.
Definition at line 41 of file vtkParallelSerialWriter.h.
