| void | PrintSelf (ostream &, vtkIndent) override |
| int | ProcessOneMessage (const vtkClientServerStream &css, int message) |
| | Process the message with the given index in the given stream. More...
| const vtkClientServerStream * | GetMessageFromID (vtkClientServerID id) |
| | Get the message for an ID. More...
| const vtkClientServerStream & | GetLastResult () const |
| | Get the last result message. More...
| vtkObjectBase * | GetObjectFromID (vtkClientServerID id) |
| | Return a pointer to a vtkObjectBase for an ID whose message contains only the one object. More...
| vtkObjectBase * | GetObjectFromID (vtkClientServerID id, int noerror) |
| vtkClientServerID | GetIDFromObject (vtkObjectBase *key) |
| | Return an ID given a pointer to a vtkObjectBase (or 0 if object is not found) More...
| int | NewInstance (vtkObjectBase *obj, vtkClientServerID id) |
| | Called by generated code to register a new class instance. More...
| VTK_NEWINSTANCE vtkObjectBase * | NewInstance (const char *classname) |
| | Creates a new instance for the class specified using the interpreter. More...
| int | NewObserver (vtkObject *obj, const char *event, const vtkClientServerStream &css) |
| | Called by generated code to add an observer to a wrapped object. More...
| void | AddCommandFunction (const char *cname, vtkClientServerCommandFunction func, void *ctx=NULL, vtkContextFreeFunction ctx_free=NULL) |
| | Add a command function for a class. More...
| bool | HasCommandFunction (const char *cname) |
| | Return true if the classname has a command function, false otherwise. More...
| int | CallCommandFunction (const char *classname, vtkObjectBase *ptr, const char *method, const vtkClientServerStream &msg, vtkClientServerStream &result) |
| | Call a command function. More...
| void | AddNewInstanceFunction (const char *cname, vtkClientServerNewInstanceFunction f, void *ctx=NULL, vtkContextFreeFunction ctx_free=NULL) |
| | Add a function used to create new objects. More...
| void | ClearLastResult () |
| | Resets the LastResult stream. More...
| vtkClientServerID | GetNextAvailableId () |
| | Return the next available Id that can be used to create a new object. More...
| int | ProcessStream (const unsigned char *msg, size_t msgLength) |
| | Process all messages in a given vtkClientServerStream. More...
| int | ProcessStream (const vtkClientServerStream &css) |
| void | SetLogFile (const char *name) |
| | Get/Set a stream to which an execution log is written. More...
| virtual void | SetLogStream (ostream *ostr) |
| virtual ostream * | GetLogStream () |
| int | Load (const char *moduleName) |
| | Dynamically load a wrapper module into the interpreter. More...
| int | Load (const char *moduleName, const char *const *optionalPaths) |
Run-time VTK interpreter.
vtkClientServerInterpreter will process messages stored in a vtkClientServerStream. This allows run-time creation and execution of VTK programs.
Definition at line 63 of file vtkClientServerInterpreter.h.
