| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVRecoverGeometryWireframe () |
| | ~vtkPVRecoverGeometryWireframe () override |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Get corrected wireframe from tessellated facets.
When vtkPVGeometryFilter tessellates nonlinear faces into linear approximations, it introduces edges in the middle of the facets of the original mesh (as any valid tessellation would). To correct for this, vtkPVGeometryFilter also writes out some fields that allows use to identify the edges that are actually part of the original mesh. This filter works in conjunction with vtkPVGeometryFilter by taking its output, adding an edge flag and making the appropriate adjustments so that rendering with line fill mode will make the correct wireframe.
- See also
- vtkPVGeometryFilter
Definition at line 48 of file vtkPVRecoverGeometryWireframe.h.
