| void | SetGridAxes (vtkPVGridAxes3DActor *gridAxes) |
| virtual vtkPVGridAxes3DActor * | GetGridAxes () |
| void | SetVisibility (bool) override |
| | Get/Set the visibility for this representation. More...
| void | SetGridAxesVisibility (bool) |
| void | SetPosition (double pos[3]) |
| void | SetPosition (double x, double y, double z) |
| void | SetScale (double scale[3]) |
| void | SetScale (double x, double y, double z) |
| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPVGridAxes3DRepresentation () |
| | ~vtkPVGridAxes3DRepresentation () override |
| int | RequestData (vtkInformation *req, vtkInformationVector **inInfoVec, vtkInformationVector *outInfoVec) override |
| void | UpdateVisibility () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
