| void | CopyFromObject (vtkObject *) override |
| | Transfer information about a single object into this object. More...
| void | SetComponentName (vtkIdType component, const char *name) |
| | Set the name for a component. More...
| const char * | GetComponentName (vtkIdType component) |
| | Get the component name for a given component. More...
| void | GetDataTypeRange (double range[2]) |
| | This method return the Min and Max possible range of the native data type. More...
| int | Compare (vtkPVArrayInformation *info) |
| | Returns 1 if the array can be combined. More...
| void | DeepCopy (vtkPVArrayInformation *info) |
| void | AddInformation (vtkPVInformation *) override |
| | Merge another information object. More...
| void | Initialize () |
| | Remove all infommation. More...
| virtual void | SetDataType (int) |
| | DataType is the string name of the data type: VTK_FLOAT ... More...
| virtual int | GetDataType () |
| virtual void | SetName (const char *) |
| | Set/get array's name. More...
| virtual char * | GetName () |
| void | SetNumberOfComponents (int numComps) |
| | Changing the number of components clears the ranges back to the default. More...
| virtual int | GetNumberOfComponents () |
| virtual void | SetNumberOfTuples (vtkTypeInt64) |
| | Set/get the array's length. More...
| virtual vtkTypeInt64 | GetNumberOfTuples () |
| void | SetComponentRange (int comp, double min, double max) |
| | There is a range for each component. More...
| void | SetComponentRange (int comp, double *range) |
| double * | GetComponentRange (int component) VTK_SIZEHINT(2) |
| void | GetComponentRange (int comp, double range[2]) |
| void | SetComponentFiniteRange (int comp, double min, double max) |
| void | SetComponentFiniteRange (int comp, double *range) |
| double * | GetComponentFiniteRange (int component) |
| void | GetComponentFiniteRange (int comp, double range[2]) |
| void | CopyToStream (vtkClientServerStream *) override |
| | Manage a serialized version of the information. More...
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual void | SetIsPartial (int) |
| | If IsPartial is true, this array is in only some of the parts of a multi-block dataset. More...
| virtual int | GetIsPartial () |
| void | AddInformationKeys (vtkPVArrayInformation *info) |
| | Merge (union) keys into this object. More...
| void | AddInformationKey (const char *location, const char *name) |
| void | AddUniqueInformationKey (const char *location, const char *name) |
| int | GetNumberOfInformationKeys () |
| | Get information on the InformationKeys of this array. More...
| const char * | GetInformationKeyLocation (int) |
| const char * | GetInformationKeyName (int) |
| int | HasInformationKey (const char *location, const char *name) |
| int | GetNumberOfStringValues () |
| | For string arrays, this returns first few non-empty values. More...
| const char * | GetStringValue (int) |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| | Serialize/Deserialize the parameters that control how/what information is gathered. More...
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| | Set/get whether to gather information only from the root. More...
Generic attribute information like type.
This objects is for eliminating direct access to vtkDataObjects by the "client". Only vtkPVPart and vtkPVProcessModule should access the data directly. At the moment, this object is only a container and has no useful methods for operating on data.
Definition at line 33 of file vtkPVGenericAttributeInformation.h.
