Information object that can be used to obtain information about a file/directory. More...
#include <vtkPVFileInformation.h>
| enum | FileTypes { INVALID = 0, SINGLE_FILE, SINGLE_FILE_LINK, DIRECTORY, DIRECTORY_LINK, FILE_GROUP, DRIVE, NETWORK_ROOT, NETWORK_DOMAIN, NETWORK_SERVER, NETWORK_SHARE, DIRECTORY_GROUP } |
| typedef vtkPVInformation | Superclass |
Public Types inherited from vtkPVInformation | |
| void | CopyFromObject (vtkObject *object) override |
| Transfer information about a single object into this object. More... | |
| void | Initialize () |
| Initializes the information object. More... | |
| void | CopyToStream (vtkClientServerStream *) override |
| Manage a serialized version of the information. More... | |
| void | CopyFromStream (const vtkClientServerStream *) override |
| virtual char * | GetName () |
| Get the name of the file/directory whose information is represented by this object. More... | |
| virtual char * | GetFullPath () |
| Get the full path of the file/directory whose information is represented by this object. More... | |
| virtual int | GetType () |
| Get the type of this file object. More... | |
| virtual bool | GetHidden () |
| Get the state of the hidden flag for the file/directory. More... | |
| virtual vtkCollection * | GetContents () |
| Get the Contents for this directory. More... | |
| virtual char * | GetExtension () |
| virtual long long | GetSize () |
| virtual time_t | GetModificationTime () |
Public Member Functions inherited from vtkPVInformation | |
| virtual void | AddInformation (vtkPVInformation *) |
| Merge another information object. More... | |
| virtual void | CopyParametersToStream (vtkMultiProcessStream &) |
| Serialize/Deserialize the parameters that control how/what information is gathered. More... | |
| virtual void | CopyParametersFromStream (vtkMultiProcessStream &) |
| virtual int | GetRootOnly () |
| Set/get whether to gather information only from the root. More... | |
| static vtkPVFileInformation * | New () |
| static vtkPVFileInformation * | SafeDownCast (vtkObject *o) |
| static bool | IsDirectory (int t) |
| Helper that returns whether a FileType is a directory (DIRECTORY, DRIVE, NETWORK_ROOT, etc...) Or in other words, a type that we can do a DirectoryListing on. More... | |
| static std::string | GetParaViewSharedResourcesDirectory () |
| Returns the path to the base data directory path holding various files packaged with ParaView. More... | |
| static std::string | GetParaViewExampleFilesDirectory () |
| Return the path of the example data packaged with ParaView. More... | |
| static std::string | GetParaViewDocDirectory () |
| Return the path of the documents packaged with ParaView. More... | |
Static Public Member Functions inherited from vtkPVInformation | |
| static vtkPVInformation * | SafeDownCast (vtkObject *o) |
Protected Attributes | |
| vtkCollection * | Contents |
| vtkFileSequenceParser * | SequenceParser |
| char * | Name |
| char * | FullPath |
| int | Type |
| bool | Hidden |
| char * | Extension |
| long long | Size |
| time_t | ModificationTime |
| int | FastFileTypeDetection |
| bool | ReadDetailedFileInformation |
Protected Attributes inherited from vtkPVInformation | |
| int | RootOnly |
vtkPVFileInformation can be used to collect information about file or directory. vtkPVFileInformation can collect information from a vtkPVFileInformationHelper object alone.
Definition at line 39 of file vtkPVFileInformation.h.
Definition at line 43 of file vtkPVFileInformation.h.
| Enumerator | |
| INVALID | |
| SINGLE_FILE | |
| SINGLE_FILE_LINK | |
| DIRECTORY | |
| DIRECTORY_LINK | |
| FILE_GROUP | |
| DRIVE | |
| NETWORK_ROOT | |
| NETWORK_DOMAIN | |
| NETWORK_SERVER | |
| NETWORK_SHARE | |
| DIRECTORY_GROUP | |
Definition at line 60 of file vtkPVFileInformation.h.
Reimplemented from vtkPVInformation.
The object must be a vtkPVFileInformationHelper.
Implements vtkPVInformation.
| void vtkPVFileInformation::Initialize | ( | ) |
Returns a collection with vtkPVFileInformation objects for the contents of this directory if Type == DIRECTORY or the contents of this file group if Type == FILE_GROUP or the contents of this directory group if Type == DIRECTORY_GROUP.
protectedvirtual |
protectedvirtual |
protectedvirtual |
Definition at line 152 of file vtkPVFileInformation.h.
Definition at line 153 of file vtkPVFileInformation.h.
Definition at line 155 of file vtkPVFileInformation.h.
Definition at line 156 of file vtkPVFileInformation.h.
Definition at line 157 of file vtkPVFileInformation.h.
Definition at line 158 of file vtkPVFileInformation.h.
Definition at line 159 of file vtkPVFileInformation.h.
Definition at line 160 of file vtkPVFileInformation.h.
Definition at line 161 of file vtkPVFileInformation.h.
Definition at line 177 of file vtkPVFileInformation.h.
Definition at line 178 of file vtkPVFileInformation.h.
