Parses out the base file name of a file sequence and also the specific index of the given file.
| bool | ParseFileSequence (const char *file) |
| | Extract base file name sequence from the file. More...
| virtual char * | GetSequenceName () |
| | Getter to use to get the sequence name after calling ParseFileSequence. More...
| virtual int | GetSequenceIndex () |
| | Getter to use to get the sequence index after calling ParseFileSequence. More...
| virtual std::string | GetSequenceIndexString () |
| | Getter to use to get the sequence index string after calling ParseFileSequence. More...
Given a file name (without path). I will extract the base portion of the file name that is common to all the files in the sequence. It will also provide the current sequence index of the provided file name. by several vtkPVUpdateSuppressor objects.
Definition at line 40 of file vtkFileSequenceParser.h.
