Public Types | Public Member Functions | Static Public Member Functions | Protected Attributes | List of all members
vtkPVAMRDualClip Class Reference
Generates contour given one or more cell array and a volume fraction value. More...
#include <vtkPVAMRDualClip.h>
Inheritance diagram for vtkPVAMRDualClip:
Collaboration diagram for vtkPVAMRDualClip:
typedef vtkAMRDualClip Superclass
- Public Types inherited from vtkAMRDualClip
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
 vtkPVAMRDualClip ()
 ~vtkPVAMRDualClip () override
void AddInputCellArrayToProcess (const char *name)
 Add to list of cell arrays which are used for generating contours. More...
void ClearInputCellArrayToProcess ()
virtual double GetVolumeFractionSurfaceValue ()
 Get / Set volume fraction value. More...
virtual void SetVolumeFractionSurfaceValue (double)
- Public Member Functions inherited from vtkAMRDualClip
virtual void SetIsoValue (double)
virtual double GetIsoValue ()
virtual vtkMultiProcessControllerGetController ()
virtual void SetController (vtkMultiProcessController *)
virtual void SetEnableInternalDecimation (int)
 These are to evaluate performances. More...
virtual int GetEnableInternalDecimation ()
virtual void SetEnableDegenerateCells (int)
virtual int GetEnableDegenerateCells ()
virtual void EnableDegenerateCellsOn ()
virtual void EnableDegenerateCellsOff ()
virtual void SetEnableMultiProcessCommunication (int)
virtual int GetEnableMultiProcessCommunication ()
virtual void EnableMultiProcessCommunicationOn ()
virtual void EnableMultiProcessCommunicationOff ()
virtual void SetEnableMergePoints (int)
 This flag causes blocks to share locators so there are no boundary edges between blocks. More...
virtual int GetEnableMergePoints ()
virtual void EnableMergePointsOn ()
virtual void EnableMergePointsOff ()
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithmNewInstance () const
vtkMultiBlockDataSetGetOutput ()
vtkMultiBlockDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVAMRDualClipNew ()
static vtkPVAMRDualClipSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkAMRDualClip
static vtkAMRDualClipNew ()
static vtkAMRDualClipSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithmNew ()
static vtkMultiBlockDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
double VolumeFractionSurfaceValue
vtkPVAMRDualClipInternal * Implementation
- Protected Attributes inherited from vtkAMRDualClip
double IsoValue
int EnableInternalDecimation
int EnableDegenerateCells
int EnableMultiProcessCommunication
int EnableMergePoints
vtkUnstructuredGridMesh
vtkIntArrayBlockIdCellArray
vtkUnsignedCharArrayLevelMaskPointArray
vtkAMRDualGridHelperHelper
vtkPointsPoints
vtkCellArrayCells
vtkMultiProcessControllerController
intMessageBuffer
intMessageBufferLength
vtkAMRDualClipLocator * BlockLocator
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Protected Member Functions inherited from vtkAMRDualClip
 vtkAMRDualClip ()
 ~vtkAMRDualClip () override
void InitializeCopyAttributes (vtkNonOverlappingAMR *hbdsInput, vtkDataSet *mesh)
vtkMultiBlockDataSetDoRequestData (vtkNonOverlappingAMR *input, const char *arrayNameToProcess)
 Not a pipeline function. More...
void ShareBlockLocatorWithNeighbors (vtkAMRDualGridHelperBlock *block)
void ProcessBlock (vtkAMRDualGridHelperBlock *block, int blockId, const char *arrayName)
void ProcessDualCell (vtkAMRDualGridHelperBlock *block, int blockId, int x, int y, int z, vtkIdType cornerOffsets[8], vtkDataArray *volumeFractionArray)
void InitializeLevelMask (vtkAMRDualGridHelperBlock *block)
void ShareLevelMask (vtkAMRDualGridHelperBlock *block)
void DistributeLevelMasks ()
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
.SEE vtkAMRDualClip
Definition at line 35 of file vtkPVAMRDualClip.h.
Definition at line 39 of file vtkPVAMRDualClip.h.
◆ vtkPVAMRDualClip()
vtkPVAMRDualClip::vtkPVAMRDualClip ( )
◆ ~vtkPVAMRDualClip()
vtkPVAMRDualClip::~vtkPVAMRDualClip ( )
override
static vtkPVAMRDualClip* vtkPVAMRDualClip::New ( )
virtual const char* vtkPVAMRDualClip::GetClassName ( )
Reimplemented from vtkAMRDualClip.
static int vtkPVAMRDualClip::IsTypeOf ( const char *  type)
virtual int vtkPVAMRDualClip::IsA ( const char *  type)
static vtkPVAMRDualClip* vtkPVAMRDualClip::SafeDownCast ( vtkObject o)
void vtkPVAMRDualClip::PrintSelf ( ostream &  os,
◆ AddInputCellArrayToProcess()
void vtkPVAMRDualClip::AddInputCellArrayToProcess ( const char *  name)
◆ ClearInputCellArrayToProcess()
void vtkPVAMRDualClip::ClearInputCellArrayToProcess ( )
◆ GetVolumeFractionSurfaceValue()
virtual double vtkPVAMRDualClip::GetVolumeFractionSurfaceValue ( )
◆ SetVolumeFractionSurfaceValue()
virtual void vtkPVAMRDualClip::SetVolumeFractionSurfaceValue ( double  )
◆ RequestData()
int vtkPVAMRDualClip::RequestData ( vtkInformation ,
vtkInformationVector **  ,
◆ VolumeFractionSurfaceValue
double vtkPVAMRDualClip::VolumeFractionSurfaceValue
Definition at line 68 of file vtkPVAMRDualClip.h.
◆ Implementation
vtkPVAMRDualClipInternal* vtkPVAMRDualClip::Implementation
Definition at line 70 of file vtkPVAMRDualClip.h.
