vtkAMRDualClip Class Reference
Clip (with scalars) an AMR volume to unstructured grid. More...
#include <vtkAMRDualClip.h>
Inheritance diagram for vtkAMRDualClip:
Collaboration diagram for vtkAMRDualClip:
typedef vtkMultiBlockDataSetAlgorithm Superclass
- Public Types inherited from vtkMultiBlockDataSetAlgorithm
enum  DesiredOutputPrecision
virtual void SetIsoValue (double)
virtual double GetIsoValue ()
virtual vtkMultiProcessControllerGetController ()
virtual void SetController (vtkMultiProcessController *)
virtual void SetEnableInternalDecimation (int)
 These are to evaluate performances. More...
virtual int GetEnableInternalDecimation ()
virtual void SetEnableDegenerateCells (int)
virtual int GetEnableDegenerateCells ()
virtual void EnableDegenerateCellsOn ()
virtual void EnableDegenerateCellsOff ()
virtual void SetEnableMultiProcessCommunication (int)
virtual int GetEnableMultiProcessCommunication ()
virtual void EnableMultiProcessCommunicationOn ()
virtual void EnableMultiProcessCommunicationOff ()
virtual void SetEnableMergePoints (int)
 This flag causes blocks to share locators so there are no boundary edges between blocks. More...
virtual int GetEnableMergePoints ()
virtual void EnableMergePointsOn ()
virtual void EnableMergePointsOff ()
- Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
vtkMultiBlockDataSetAlgorithmNewInstance () const
vtkMultiBlockDataSetGetOutput ()
vtkMultiBlockDataSetGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkAMRDualClipNew ()
static vtkAMRDualClipSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkMultiBlockDataSetAlgorithm
static vtkMultiBlockDataSetAlgorithmNew ()
static vtkMultiBlockDataSetAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkAMRDualClip ()
 ~vtkAMRDualClip () override
void InitializeCopyAttributes (vtkNonOverlappingAMR *hbdsInput, vtkDataSet *mesh)
vtkMultiBlockDataSetDoRequestData (vtkNonOverlappingAMR *input, const char *arrayNameToProcess)
 Not a pipeline function. More...
void ShareBlockLocatorWithNeighbors (vtkAMRDualGridHelperBlock *block)
void ProcessBlock (vtkAMRDualGridHelperBlock *block, int blockId, const char *arrayName)
void ProcessDualCell (vtkAMRDualGridHelperBlock *block, int blockId, int x, int y, int z, vtkIdType cornerOffsets[8], vtkDataArray *volumeFractionArray)
void InitializeLevelMask (vtkAMRDualGridHelperBlock *block)
void ShareLevelMask (vtkAMRDualGridHelperBlock *block)
void DistributeLevelMasks ()
- Protected Member Functions inherited from vtkMultiBlockDataSetAlgorithm
 vtkMultiBlockDataSetAlgorithm ()
 ~vtkMultiBlockDataSetAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
vtkDataObjectGetInput (int port)
virtual int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *)
 vtkAlgorithm ()
 ~vtkAlgorithm ()
double IsoValue
int EnableInternalDecimation
int EnableDegenerateCells
int EnableMultiProcessCommunication
int EnableMergePoints
vtkUnstructuredGridMesh
vtkIntArrayBlockIdCellArray
vtkUnsignedCharArrayLevelMaskPointArray
vtkAMRDualGridHelperHelper
vtkPointsPoints
vtkCellArrayCells
vtkMultiProcessControllerController
intMessageBuffer
intMessageBufferLength
vtkAMRDualClipLocator * BlockLocator
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
This filter clips an AMR volume but does not copy attributes yet. This filter has two important features. First is that the level transitions are handled correctly, and second is that internal cells are decimated. I use a variation of degenerate points/cells used for level transitions.
Definition at line 51 of file vtkAMRDualClip.h.
Definition at line 55 of file vtkAMRDualClip.h.
◆ vtkAMRDualClip()
vtkAMRDualClip::vtkAMRDualClip ( )
◆ ~vtkAMRDualClip()
vtkAMRDualClip::~vtkAMRDualClip ( )
static vtkAMRDualClip* vtkAMRDualClip::New ( )
virtual const char* vtkAMRDualClip::GetClassName ( )
Reimplemented in vtkPVAMRDualClip.
static int vtkAMRDualClip::IsTypeOf ( const char *  type)
virtual int vtkAMRDualClip::IsA ( const char *  type)
Reimplemented from vtkMultiBlockDataSetAlgorithm.
static vtkAMRDualClip* vtkAMRDualClip::SafeDownCast ( vtkObject o)
void vtkAMRDualClip::PrintSelf ( ostream &  os,
◆ SetIsoValue()
virtual void vtkAMRDualClip::SetIsoValue ( double  )
◆ GetIsoValue()
virtual double vtkAMRDualClip::GetIsoValue ( )
◆ SetEnableInternalDecimation()
virtual void vtkAMRDualClip::SetEnableInternalDecimation ( int  )
You can turn off degenerate cells and multiprocess communication to see how they affect speed of execution. Degenerate cells is the meshing between levels in the grid.
◆ GetEnableInternalDecimation()
virtual int vtkAMRDualClip::GetEnableInternalDecimation ( )
◆ SetEnableDegenerateCells()
virtual void vtkAMRDualClip::SetEnableDegenerateCells ( int  )
◆ GetEnableDegenerateCells()
virtual int vtkAMRDualClip::GetEnableDegenerateCells ( )
◆ EnableDegenerateCellsOn()
virtual void vtkAMRDualClip::EnableDegenerateCellsOn ( )
◆ EnableDegenerateCellsOff()
virtual void vtkAMRDualClip::EnableDegenerateCellsOff ( )
◆ SetEnableMultiProcessCommunication()
virtual void vtkAMRDualClip::SetEnableMultiProcessCommunication ( int  )
◆ GetEnableMultiProcessCommunication()
virtual int vtkAMRDualClip::GetEnableMultiProcessCommunication ( )
◆ EnableMultiProcessCommunicationOn()
virtual void vtkAMRDualClip::EnableMultiProcessCommunicationOn ( )
◆ EnableMultiProcessCommunicationOff()
virtual void vtkAMRDualClip::EnableMultiProcessCommunicationOff ( )
◆ SetEnableMergePoints()
virtual void vtkAMRDualClip::SetEnableMergePoints ( int  )
It does not eliminate boundary edges between processes.
◆ GetEnableMergePoints()
virtual int vtkAMRDualClip::GetEnableMergePoints ( )
◆ EnableMergePointsOn()
virtual void vtkAMRDualClip::EnableMergePointsOn ( )
◆ EnableMergePointsOff()
virtual void vtkAMRDualClip::EnableMergePointsOff ( )
◆ GetController()
virtual vtkMultiProcessController* vtkAMRDualClip::GetController ( )
◆ SetController()
virtual void vtkAMRDualClip::SetController ( vtkMultiProcessController )
◆ RequestData()
int vtkAMRDualClip::RequestData ( vtkInformation ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ InitializeCopyAttributes()
void vtkAMRDualClip::InitializeCopyAttributes ( vtkNonOverlappingAMR hbdsInput,
vtkDataSet mesh
◆ DoRequestData()
vtkMultiBlockDataSet* vtkAMRDualClip::DoRequestData ( vtkNonOverlappingAMR input,
const char *  arrayNameToProcess
This is a helper function that allows creating a new data set given a input and a cell array name.
◆ FillInputPortInformation()
int vtkAMRDualClip::FillInputPortInformation ( int  port,
vtkInformation info
◆ FillOutputPortInformation()
int vtkAMRDualClip::FillOutputPortInformation ( int  port,
vtkInformation info
◆ ShareBlockLocatorWithNeighbors()
void vtkAMRDualClip::ShareBlockLocatorWithNeighbors ( vtkAMRDualGridHelperBlock block)
◆ ProcessBlock()
void vtkAMRDualClip::ProcessBlock ( vtkAMRDualGridHelperBlock block,
int  blockId,
◆ ProcessDualCell()
void vtkAMRDualClip::ProcessDualCell ( vtkAMRDualGridHelperBlock block,
int  blockId,
int  x,
int  y,
int  z,
vtkDataArray volumeFractionArray
◆ InitializeLevelMask()
void vtkAMRDualClip::InitializeLevelMask ( vtkAMRDualGridHelperBlock block)
◆ ShareLevelMask()
void vtkAMRDualClip::ShareLevelMask ( vtkAMRDualGridHelperBlock block)
◆ DistributeLevelMasks()
void vtkAMRDualClip::DistributeLevelMasks ( )
◆ IsoValue
double vtkAMRDualClip::IsoValue
Definition at line 95 of file vtkAMRDualClip.h.
◆ EnableInternalDecimation
int vtkAMRDualClip::EnableInternalDecimation
Definition at line 98 of file vtkAMRDualClip.h.
int vtkAMRDualClip::EnableDegenerateCells
Definition at line 99 of file vtkAMRDualClip.h.
int vtkAMRDualClip::EnableMultiProcessCommunication
Definition at line 100 of file vtkAMRDualClip.h.
◆ EnableMergePoints
int vtkAMRDualClip::EnableMergePoints
Definition at line 101 of file vtkAMRDualClip.h.
◆ Mesh
vtkUnstructuredGrid* vtkAMRDualClip::Mesh
Definition at line 104 of file vtkAMRDualClip.h.
◆ BlockIdCellArray
vtkIntArray* vtkAMRDualClip::BlockIdCellArray
Definition at line 136 of file vtkAMRDualClip.h.
◆ LevelMaskPointArray
vtkUnsignedCharArray* vtkAMRDualClip::LevelMaskPointArray
Definition at line 137 of file vtkAMRDualClip.h.
◆ Helper
vtkAMRDualGridHelper* vtkAMRDualClip::Helper
Definition at line 140 of file vtkAMRDualClip.h.
◆ Points
vtkPoints* vtkAMRDualClip::Points
Definition at line 141 of file vtkAMRDualClip.h.
◆ Cells
vtkCellArray* vtkAMRDualClip::Cells
Definition at line 142 of file vtkAMRDualClip.h.
◆ Controller
vtkMultiProcessController* vtkAMRDualClip::Controller
Definition at line 144 of file vtkAMRDualClip.h.
◆ MessageBuffer
int* vtkAMRDualClip::MessageBuffer
Definition at line 148 of file vtkAMRDualClip.h.
◆ MessageBufferLength
int* vtkAMRDualClip::MessageBufferLength
Definition at line 149 of file vtkAMRDualClip.h.
◆ BlockLocator
vtkAMRDualClipLocator* vtkAMRDualClip::BlockLocator
Definition at line 151 of file vtkAMRDualClip.h.
