| | vtkAlgorithm::ProcessRequest() equivalent for rendering passes. More...
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| void | SetBackfaceAmbientColor (double r, double g, double b) |
| void | SetBackfaceDiffuseColor (double r, double g, double b) |
| void | SetBackfaceOpacity (double val) |
| virtual void | SetBackfaceRepresentation (int) |
| | Set the backface representation. More...
| virtual int | GetBackfaceRepresentation () |
| virtual void | SetSuppressLOD (bool suppress) |
| | Enable/Disable LOD;. More...
| virtual void | SetRepresentation (const char *) |
| | Overload to set representation type using string. More...
| vtkDataObject * | GetRenderedDataObject (int port) override |
| virtual void | SetNormalArray (const char *val) |
| | Set the normal array used for smooth shading. More...
| virtual void | SetTCoordArray (const char *val) |
| | Set the texture coordinates array used for texture mapping. More...
| virtual void | SetTangentArray (const char *val) |
| | Set the tangent coordinates array used for normal mapping. More...
| virtual void | SetUseOutline (int) |
| void | SetTriangulate (int) |
| void | SetNonlinearSubdivisionLevel (int) |
| virtual void | SetGenerateFeatureEdges (bool) |
| virtual void | SetAmbientColor (double r, double g, double b) |
| virtual void | SetColor (double r, double g, double b) |
| virtual void | SetDiffuseColor (double r, double g, double b) |
| virtual void | SetEdgeColor (double r, double g, double b) |
| virtual void | SetInteractiveSelectionColor (double r, double g, double b) |
| virtual void | SetInterpolation (int val) |
| virtual void | SetLineWidth (double val) |
| virtual void | SetOpacity (double val) |
| virtual void | SetPointSize (double val) |
| virtual void | SetSpecularColor (double r, double g, double b) |
| virtual void | SetSpecularPower (double val) |
| virtual void | SetLuminosity (double val) |
| virtual void | SetRenderPointsAsSpheres (bool) |
| virtual void | SetRenderLinesAsTubes (bool) |
| virtual void | SetRoughness (double val) |
| virtual void | SetMetallic (double val) |
| virtual void | SetEdgeTint (double r, double g, double b) |
| virtual void | SetBaseColorTexture (vtkTexture *tex) |
| virtual void | SetMaterialTexture (vtkTexture *tex) |
| virtual void | SetNormalTexture (vtkTexture *tex) |
| virtual void | SetEmissiveTexture (vtkTexture *tex) |
| virtual void | SetNormalScale (double val) |
| virtual void | SetOcclusionStrength (double val) |
| virtual void | SetEmissiveFactor (double rval, double gval, double bval) |
| virtual void | SetOrientation (double, double, double) |
| virtual void | SetOrigin (double, double, double) |
| virtual void | SetPickable (int val) |
| virtual void | SetPosition (double, double, double) |
| virtual void | SetScale (double, double, double) |
| virtual void | SetTexture (vtkTexture *) |
| virtual void | SetUserTransform (const double[16]) |
| virtual void | SetFlipTextures (bool) |
| virtual void | SetRepeatTextures (bool) |
| virtual bool | GetRepeatTextures () |
| virtual void | SetInterpolateTextures (bool) |
| virtual bool | GetInterpolateTextures () |
| virtual void | SetUseMipmapTextures (bool) |
| virtual bool | GetUseMipmapTextures () |
| virtual void | SetInterpolateScalarsBeforeMapping (int val) |
| virtual void | SetLookupTable (vtkScalarsToColors *val) |
| virtual void | SetSeamlessU (bool) |
| virtual void | SetSeamlessV (bool) |
| virtual void | SetSelection (vtkSelection *selection) |
| | Sets the selection used by the mapper. More...
| vtkPVLODActor * | GetActor () |
| | Provides access to the actor used by this representation. More...
| const char * | GetColorArrayName () |
| | Convenience method to get the array name used to scalar color with. More...
| virtual void | SetMaterial (const char *) |
| | For OSPRay, choose from among available materials. More...
| virtual void | SetShaderReplacements (const char *) |
| | Specify shader replacements using a Json string. More...
| virtual void | SetArrayIdNames (const char *pointArray, const char *cellArray) |
| | Specify the array names used for the selection. More...
| void | SetBlockColorsDistinctValues (int distinctValues) |
| | Determines the number of distinct values in vtkBlockColors See also vtkPVGeometryFilter. More...
| int | GetBlockColorsDistinctValues () |
| virtual void | SetAmbient (double) |
| | Set the lighting properties of the object. More...
| virtual void | SetDiffuse (double) |
| virtual void | SetSpecular (double) |
| virtual double | GetAmbient () |
| virtual double | GetDiffuse () |
| virtual double | GetSpecular () |
| void | SetCoordinateShiftScaleMethod (int val) |
| | Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More...
| int | GetCoordinateShiftScaleMethod () |
| virtual void | SetRepresentation (int) |
| | Set the representation type. More...
| virtual int | GetRepresentation () |
| virtual void | SetRequestGhostCellsIfNeeded (bool) |
| | Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More...
| virtual bool | GetRequestGhostCellsIfNeeded () |
| virtual void | RequestGhostCellsIfNeededOn () |
| virtual void | RequestGhostCellsIfNeededOff () |
| virtual void | SetMapScalars (int val) |
| | Sets if scalars are mapped through a color-map or are used directly as colors. More...
| virtual void | SetStatic (int val) |
| virtual void | SetBlockVisibility (unsigned int index, bool visible) |
| | Set/get the visibility for a single block. More...
| virtual bool | GetBlockVisibility (unsigned int index) const |
| virtual void | RemoveBlockVisibility (unsigned int index, bool=true) |
| virtual void | RemoveBlockVisibilities () |
| virtual void | SetBlockColor (unsigned int index, double r, double g, double b) |
| | Set/get the color for a single block. More...
| virtual void | SetBlockColor (unsigned int index, double *color) |
| virtual double * | GetBlockColor (unsigned int index) |
| virtual void | RemoveBlockColor (unsigned int index) |
| virtual void | RemoveBlockColors () |
| virtual void | SetBlockOpacity (unsigned int index, double opacity) |
| | Set/get the opacityfor a single block. More...
| virtual void | SetBlockOpacity (unsigned int index, double *opacity) |
| virtual double | GetBlockOpacity (unsigned int index) |
| virtual void | RemoveBlockOpacity (unsigned int index) |
| virtual void | RemoveBlockOpacities () |
| virtual void | SetEnableScaling (int v) |
| | For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More...
| virtual void | SetScalingArrayName (const char *) |
| virtual void | SetScalingFunction (vtkPiecewiseFunction *pwf) |
| virtual void | SetUseDataPartitions (bool) |
| | Specify whether or not to redistribute the data. More...
| virtual bool | GetUseDataPartitions () |
| virtual void | SetUseShaderReplacements (bool) |
| | Specify whether or not to shader replacements string must be used. More...
| virtual bool | GetUseShaderReplacements () |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkGeometryRepresentationWithFaces () |
| | ~vtkGeometryRepresentationWithFaces () override |
| void | SetupDefaults () override |
| | This method is called in the constructor. More...
| void | UpdateColoringParameters () override |
| | Passes on parameters to vtkProperty and vtkMapper. More...
| bool | NeedsOrderedCompositing () override |
| | Returns true if this representation has translucent geometry. More...
| | vtkGeometryRepresentation () |
| | ~vtkGeometryRepresentation () override |
| | Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
| | Overridden to request correct ghost-level to avoid internal surfaces. More...
| virtual vtkPVLODActor * | GetRenderedProp () |
| | Used in ConvertSelection to locate the prop used for actual rendering. More...
| void | HandleGeometryRepresentationProgress (vtkObject *caller, unsigned long, void *) |
| void | UpdateBlockAttributes (vtkMapper *mapper) |
| | Block attributes in a mapper are referenced to each block through DataObject pointers. More...
| void | ComputeVisibleDataBounds () |
| | Computes the bounds of the visible data based on the block visibilities in the composite data attributes of the mapper. More...
| void | UpdateShaderReplacements () |
| | Update the mapper with the shader replacement strings if feature is enabled. More...
| virtual void | SetPointArrayToProcess (int p, const char *val) |
| | Used by SetNormalArray, SetTCoordArray and SetTangentArray. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
