| int | RequestDataDescription (vtkCPDataDescription *dataDescription) override |
| | Configuration Step: The coprocessor first determines if any coprocessing needs to be done at this TimeStep/Time combination returning 1 if it does and 0 otherwise. More...
| int | CoProcess (vtkCPDataDescription *dataDescription) override |
| | Execute the pipeline. Returns 1 for success and 0 for failure. More...
| virtual void | SetOutputFrequency (int) |
| | Set the output frequency for this pipeline. The default is 1. More...
| virtual int | GetOutputFrequency () |
| virtual void | SetPaddingAmount (int) |
| | Set the padding amount for the time index portion of the generated files. More...
| virtual int | GetPaddingAmount () |
| virtual void | SetPath (std::string) |
| | Set the path to the generated files. More...
| virtual std::string | GetPath () |
| virtual int | Finalize () |
| | Finalize the pipeline before deleting it. More...
Generic PXML writer pipeline to write out the full Catalyst input datasets.
The filename will correspond to the input name/channel identifier with time step and file extension (e.g. "input_0.pvtu" for an unstructured dataset with no padding).
Definition at line 28 of file vtkCPXMLPWriterPipeline.h.
