vtkCPPythonAdaptorAPI Class Reference
Similar to vtkCPAdaptorAPI provides the implementation for API exposed to typical adaptor, such as C, Fortran, except that is adds the ability to initialize the coprocessor with Python capabilities. More...
#include <vtkCPPythonAdaptorAPI.h>
Inheritance diagram for vtkCPPythonAdaptorAPI:
Collaboration diagram for vtkCPPythonAdaptorAPI:
typedef vtkCPAdaptorAPI Superclass
- Public Types inherited from vtkCPAdaptorAPI
void PrintSelf (ostream &os, vtkIndent indent) VTK_OVERRIDE
static vtkCPPythonAdaptorAPISafeDownCast (vtkObject *o)
static void CoProcessorInitialize (const char *pythonFileName)
 Call at the start of the simulation. More...
- Static Public Member Functions inherited from vtkCPAdaptorAPI
static vtkCPAdaptorAPISafeDownCast (vtkObject *o)
static void CoProcessorInitialize ()
 call at the start of the simulation More...
static void CoProcessorFinalize ()
 call at the end of the simulation More...
static void RequestDataDescription (int *timeStep, double *time, int *coprocessThisTimeStep)
 this is the function that determines whether or not there is anything to coprocess this time step More...
static void NeedToCreateGrid (int *needGrid)
 this function sets needgrid to 1 if it does not have a copy of the grid it sets needgrid to 0 if it does have a copy of the grid but does not check if the grid is modified or needs to be updated More...
static void CoProcess ()
 do the actual coprocessing. More...
static vtkCPDataDescriptionGetCoProcessorData ()
 provides access to the vtkCPDataDescription instance. More...
static vtkCPProcessorGetCoProcessor ()
 provides access to the vtkCPProcessor instance. More...
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkCPPythonAdaptorAPI ()
 ~vtkCPPythonAdaptorAPI ()
- Static Protected Attributes inherited from vtkCPAdaptorAPI
static vtkCPDataDescriptionCoProcessorData
static vtkCPProcessorCoProcessor
static bool IsTimeDataSet
Definition at line 24 of file vtkCPPythonAdaptorAPI.h.
Definition at line 27 of file vtkCPPythonAdaptorAPI.h.
◆ vtkCPPythonAdaptorAPI()
vtkCPPythonAdaptorAPI::vtkCPPythonAdaptorAPI ( )
◆ ~vtkCPPythonAdaptorAPI()
vtkCPPythonAdaptorAPI::~vtkCPPythonAdaptorAPI ( )
virtual const char* vtkCPPythonAdaptorAPI::GetClassName ( )
Reimplemented from vtkCPAdaptorAPI.
static int vtkCPPythonAdaptorAPI::IsTypeOf ( const char *  type)
virtual int vtkCPPythonAdaptorAPI::IsA ( const char *  type)
static vtkCPPythonAdaptorAPI* vtkCPPythonAdaptorAPI::SafeDownCast ( vtkObject o)
◆ CoProcessorInitialize()
static void vtkCPPythonAdaptorAPI::CoProcessorInitialize ( const char *  pythonFileName)
Users can still call CoProcessorInitialize() without arguments, in which case Python interpretor will not be initialized and hence unavailable.
