A single log viewer widget which has a reference to the log recorder proxy. More...
#include <pqSingleLogViewerWidget.h>
| pqSingleLogViewerWidget (QWidget *parent, vtkSmartPointer< vtkSMProxy > logRecorderProxy, int rank) | |
| ~pqSingleLogViewerWidget () override=default | |
| void | refresh () |
| Refresh the log viewer. More... | |
| const vtkSmartPointer< vtkSMProxy > & | getLogRecorderProxy () const |
| Get the log recorder proxy reference hold by this widget. More... | |
| int | getRank () const |
| Get the rank of the process whose log is shown in this widget. More... | |
| void | closeEvent (QCloseEvent *) override |
| Disable log recording of the specific rank when the widget is closed. More... | |
Public Member Functions inherited from pqLogViewerWidget | |
| pqLogViewerWidget (QWidget *parent=nullptr) | |
| virtual | ~pqLogViewerWidget () override |
| void | setLog (const QString &text) |
| Set the contents of the log viewer to the provided txt. More... | |
| void | appendLog (const QString &text) |
| Append text to log. More... | |
| void | setFilterWildcard (QString wildcard) |
| Manually set the filter wildcard. More... | |
| void | scrollToTime (double time) |
| Scroll to the log near the specific time. More... | |
| void | updateColumnVisibilities () |
| Update log table column visibilities. More... | |
Signals inherited from pqLogViewerWidget | |
| void | closed () |
| void | scrolled (double time) |
Static Public Member Functions inherited from pqLogViewerWidget | |
| static QVector< QString > | extractLogParts (const QStringRef &txt, bool &is_raw) |
| Utility function to parse a line of log into parts. More... | |
Protected Slots inherited from pqLogViewerWidget | |
| void | toggleAdvanced () |
| void | exportLog () |
Definition at line 46 of file pqSingleLogViewerWidget.h.
| pqSingleLogViewerWidget::pqSingleLogViewerWidget | ( | QWidget * | parent, |
| vtkSmartPointer< vtkSMProxy > | logRecorderProxy, | ||
| int | rank | ||
| parent | The parent of this widget. |
| logRecorderProxy | has the information of server location, and the rank setting indicates which rank whose log is shown in this widget. |
| rank |
overridedefault |
| void pqSingleLogViewerWidget::refresh | ( | ) |
| const vtkSmartPointer<vtkSMProxy>& pqSingleLogViewerWidget::getLogRecorderProxy | ( | ) | const |
| int pqSingleLogViewerWidget::getRank | ( | ) | const |
