pqServerLauncher manages launching of server process using the details specified in the server configuration. More...
#include <pqServerLauncher.h>
Inherits QObject.
| pqServerLauncher (const pqServerConfiguration &configuration, QObject *parent=0) | |
| ~pqServerLauncher () override | |
| bool | connectToServer () |
| This method will launch the server process based on the configuration and connect to the server. More... | |
| pqServer * | connectedServer () const |
| on successful call to connectToServer() this method can be used to obtain pqServer connection. More... | |
| static const QMetaObject * | setServerDefaultLauncherType (const QMetaObject *) |
| Custom applications may want to extend the pqServerLauncher to customize connecting to servers. More... | |
| static const QMetaObject * | defaultServerLauncherType () |
| static pqServerLauncher * | newInstance (const pqServerConfiguration &configuration, QObject *parent=NULL) |
| Creates a new instance using the default launcher type specified. More... | |
Protected Slots | |
| void | processFailed (QProcess::ProcessError) |
| void | readStandardOutput () |
| void | readStandardError () |
| void | launchServerForReverseConnection () |
| bool | promptOptions () |
| Request the user for user-configurable options, if any. More... | |
| virtual bool | launchServer (bool show_status_dialog) |
| Called when starting a server processes using a command-startup. More... | |
| bool | processCommand (QString command, double timeout, double delay, const QProcessEnvironment *options=NULL) |
| An utility method to execute a command using a QProcess. More... | |
| virtual bool | connectToPrelaunchedServer () |
| bool | isReverseConnection () const |
| virtual void | prepareDialogForPromptOptions (QDialog &) |
| Subclasses can override this method to further customize the dialog being shown to the user to prompt for options in pqServerLauncher::promptOptions. More... | |
| pqServerConfiguration & | configuration () const |
| Provides access to the pqServerConfiguration passed to the constructor. More... | |
| QProcessEnvironment & | options () const |
| Provide access to the QProcessEnvironment. More... | |
| virtual void | updateOptionsUsingUserSelections () |
| Use this method to update the process environment using current user selections. More... | |
| virtual void | handleProcessStandardOutput (const QByteArray &data) |
| Subclasses can override this to handle output and error messages from the QProcess launched for command-startup configurations. More... | |
| virtual void | handleProcessErrorOutput (const QByteArray &data) |
pqServerConfiguration can be simple, i.e the user is expected to launch the pvserver, or complex, i.e. the user is prompted for several options a pvserver process is launched automatically. All this is handled by this class.
When launching processes or during reverse-connect, this class also shows message box that can be used by the user to abort the waiting for connection.
Definition at line 57 of file pqServerLauncher.h.
| pqServerLauncher::pqServerLauncher | ( | const pqServerConfiguration & | configuration, |
| QObject * | parent = 0 |
Such application can set the QMetaObject to use using this method. If none is set, pqServerLauncher will be created, by default. Returns the previous QMetaObject instance set, if any.
If none is specified, pqServerLauncher is created.
| bool pqServerLauncher::connectToServer | ( | ) |
Returns true if the connection was successful, otherwise returns false.
| pqServer* pqServerLauncher::connectedServer | ( | ) | const |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
Returns false if the user cancelled the dialog asking the options. Returns true if there are not user-configurable options or the user has accepted the values.
protectedvirtual |
Returns true if launch was successful else returns false.
protectedvirtual |
inlineprotectedvirtual |
Definition at line 131 of file pqServerLauncher.h.
Note this is clone of the pqServerConfiguration passed to the constructor and not the same instance.
protectedvirtual |
protectedvirtual |
Default implementation simply dumps the text to the debug/error console.
protectedvirtual |
