pqServerConfiguration corresponds to a server connection configuration.
#include <pqServerConfiguration.h>
| | pqServerConfiguration () |
| | ~pqServerConfiguration () |
| | pqServerConfiguration (vtkPVXMLElement *xml, int connectionTimeout=60) |
| | Create a server configuration with the provided xml and timeout. More...
| bool | isMutable () const |
| | Get/Set whether the configuration is mutable. More...
| void | setMutable (bool val) |
| void | setName (const QString &name) |
| | Get/Set the name for the configuration. More...
| QString | name () const |
| bool | isNameDefault () const |
| | Returns true if the name for this configuration is the default one i.e. More...
| pqServerResource | resource () const |
| | Get/Set the resource that describes the server scheme, hostname(s) and port(s). More...
| void | setResource (const QString &) |
| void | setResource (const pqServerResource &) |
| pqServerResource | actualResource () const |
| | Get the actual resource that describes the server scheme, hostname(s) and port(s). More...
| QString | URI () const |
| | get the resource URI More...
| int | connectionTimeout () const |
| | Get/Set the timeout in seconds that will be used when connecting 0 means no retry and -1 means infinite retries. More...
| void | setConnectionTimeout (int connectionTimeout) |
| StartupType | startupType () const |
| | returns the startup type for this configuration. More...
| QString | command (double &timeout, double &delay) const |
| | If startupType() == COMMAND, then this method can be used to obtain the command for the startup, from the client side. More...
| QString | execCommand (double &timeout, double &delay) const |
| | If startupType() == COMMAND, then this method can be used to obtain the command for the startup, on the remote server, contained in the exec attributes. More...
| void | setStartupToManual () |
| | changes the startup type to manual. More...
| void | setStartupToCommand (double timeout, double delay, const QString &command) |
| | changes the startup type to command. More...
| QString | toString (vtkIndent indent) const |
| | serialize to a string. More...
| pqServerConfiguration | clone () const |
| | Create a new clone (deep copying the vtkPVXMLElement). More...
| vtkPVXMLElement * | optionsXML () const |
| | returns the <Options> element, if any. More...
| vtkPVXMLElement * | hintsXML () const |
| | returns the <Hints> element, if any. More...
| bool | isPortForwarding () const |
| | Get if this is a port forwarding configuration. More...
| QString | portForwardingLocalPort () const |
| | Get the port forwarding local port. More...
These are typically read from pvsc files.
Definition at line 49 of file pqServerConfiguration.h.
◆ StartupType
◆ pqServerConfiguration() [1/2]
| pqServerConfiguration::pqServerConfiguration |
◆ ~pqServerConfiguration()
| pqServerConfiguration::~pqServerConfiguration |
◆ pqServerConfiguration() [2/2]
vtkPVXMLElement * |
xml, |
int |
connectionTimeout = 60 |
the timeout is in seconds, 0 means no retry and -1 means infinite retries.
◆ isMutable()
| bool pqServerConfiguration::isMutable |
const |
This variable is not serialized.
Definition at line 65 of file pqServerConfiguration.h.
◆ setMutable()
| void pqServerConfiguration::setMutable |
bool |
val | ) |
◆ setName()
| void pqServerConfiguration::setName |
const QString & |
name | ) |
◆ name()
| QString pqServerConfiguration::name |
const |
◆ isNameDefault()
| bool pqServerConfiguration::isNameDefault |
const |
the one that gets set when none is specified. Useful to determine "empty" configurations.
◆ resource()
◆ setResource() [1/2]
| void pqServerConfiguration::setResource |
const QString & |
◆ setResource() [2/2]
◆ actualResource()
Can be different from resource() when using SSH Port Forwarding as it will point to ip and port actually used for the tcp connection, which can be different than the server where the pvserver is running. eg. it will give you localhost:8080, instead of serverip:serverport when using port forwarding. Using this method is needed only when using low level tcp api. ressource() method should be used in any other cases.
◆ URI()
| QString pqServerConfiguration::URI |
const |
◆ connectionTimeout()
| int pqServerConfiguration::connectionTimeout |
const |
◆ setConnectionTimeout()
| void pqServerConfiguration::setConnectionTimeout |
int |
connectionTimeout | ) |
◆ startupType()
| StartupType pqServerConfiguration::startupType |
const |
There are 3 types of startup: manual, simple-command and custom-command.
◆ command()
| QString pqServerConfiguration::command |
double & |
timeout, |
double & |
delay |
| const |
Note that this does not include any information options etc. that may be specified in the startup. This is the full command to be executed on the client, which includes xterm, ssh...
◆ execCommand()
| QString pqServerConfiguration::execCommand |
double & |
timeout, |
double & |
delay |
| const |
Note that this does not include any information options etc. that may be specified in the startup. This also recovers timeout and delay attributes.
◆ setStartupToManual()
| void pqServerConfiguration::setStartupToManual |
◆ setStartupToCommand()
| void pqServerConfiguration::setStartupToCommand |
double |
timeout, |
double |
delay, |
const QString & |
command |
◆ toString()
| QString pqServerConfiguration::toString |
vtkIndent |
indent | ) |
const |
◆ clone()
◆ optionsXML()
◆ hintsXML()
◆ isPortForwarding()
| bool pqServerConfiguration::isPortForwarding |
const |
PortForwardingConfiguration uses SSH tunneling and is configured directly in xml server file
Definition at line 182 of file pqServerConfiguration.h.
◆ portForwardingLocalPort()
| QString pqServerConfiguration::portForwardingLocalPort |
const |
Initialized by the server xml if port forwarding is used. Equal to the ressource port if port forwarding is not used.
◆ startupXML()
◆ parseSshPortForwardingXML()
| void pqServerConfiguration::parseSshPortForwardingXML |
◆ sshFullCommand()
| QString pqServerConfiguration::sshFullCommand |
QString |
sshCommand, |
vtkPVXMLElement * |
sshConfigXML |
| const |
◆ termCommand()
| static QString pqServerConfiguration::termCommand |
staticprotected |
◆ sshCommand()
| static QString pqServerConfiguration::sshCommand |
staticprotected |
◆ lookForCommand()
| static QString pqServerConfiguration::lookForCommand |
QString |
command | ) |
staticprotected |
