pqServerConnectDialog is a dialog that can be used to show the user a selection of server configurations to connect to a server. More...
#include <pqServerConnectDialog.h>
Inherits QDialog.
Signals | |
| void | serverAdded () |
| Emitted when a server is added. More... | |
| void | serverDeleted () |
| Emitted when a server is deleted. More... | |
| pqServerConnectDialog (QWidget *parent=0, const pqServerResource &selector=pqServerResource()) | |
If selector is specified, only those server-configurations that match the selector's scheme and hostname are shown. More... | |
| ~pqServerConnectDialog () override | |
| const pqServerConfiguration & | configurationToConnect () const |
| returns the configuration to connect to. More... | |
| static bool | selectServer (pqServerConfiguration &selected_configuration, QWidget *dialogParent=NULL, const pqServerResource &selector=pqServerResource()) |
| convenience method to determine which server to connect. More... | |
Protected Slots | |
| void | updateConfigurations () |
| called to update the shown server configurations. More... | |
| void | onServerSelected () |
| called when user selects a server. More... | |
| void | editServer () |
| called when user clicks "edit-server" More... | |
| void | addServer () |
| called when user clicks "add-server" More... | |
| void | updateButtons () |
| Called when a server has been added or deleted. More... | |
| void | updateServerType () |
| called when user changes the server-type. More... | |
| void | goToFirstPage () |
| called to cancel . More... | |
| void | acceptConfigurationPage1 () |
| called when user accepts the configuration page #1. More... | |
| void | acceptConfigurationPage2 () |
| called when user accepts the configuration page #2. More... | |
| void | editServerStartup () |
| called to proceed to page that allows the user to edit the startup. More... | |
| void | onNameChanged () |
| void | deleteServer () |
| called to delete a server. More... | |
| void | loadServers () |
| called to load/save servers. More... | |
| void | saveServers () |
| void | connect () |
| called to connect to selected server. More... | |
| void | updateDialogTitle (int page_number) |
| called when the main-stacked widget's active page changes. More... | |
| void | fetchServers () |
| called when user clicks "Fetch Servers". More... | |
| void | authenticationRequired (QNetworkReply *, QAuthenticator *) |
| called when the importer needs authentication from the user. More... | |
| void | updateImportableConfigurations () |
| called update importable configs. More... | |
| void | importError (const QString &message) |
| called to report error from importer. More... | |
| void | importServersSelectionChanged () |
| called when user selects some servers to import. More... | |
| void | importServers () |
| called to import selected configurations. More... | |
| void | editSources () |
| called to edit the sources url. More... | |
| void | saveSourcesList () |
| void | cancelEditSources () |
| void | editConfiguration (const pqServerConfiguration &) |
This dialog can show all the server-configurations known to pqApplicationCore or show only a subset of those depending on whether a selector was specified in the constructor.
On successful completion, this dialog provides access to the server-configuration selected by the user. It does not make an real attempts to connect to that server.
Definition at line 57 of file pqServerConnectDialog.h.
| pqServerConnectDialog::pqServerConnectDialog | ( | QWidget * | parent = 0, |
| const pqServerResource & | selector = pqServerResource() |
| const pqServerConfiguration& pqServerConnectDialog::configurationToConnect | ( | ) | const |
This returns a valid response only when pqServerConnectDialog::exec() returns QDialog::Accepted.
If the selector is specified and matches a single server, then the user is not presented with a dialog, otherwise the user can choose the configuration to use to connect to the server. When the method returns true, selected_configuration will be set to the chosen configuration.
signal |
signal |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
called to cancel .
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
We update the dialog;s title text to match the page being displayed.
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
