pqPresetGroupsManager is an object to manage the groups of color map presets displayed in the pqPresetDialog. More...
#include <pqPresetGroupsManager.h>
Inherits QObject.
Signals | |
| void | groupsUpdated () |
| Fired whenever loadGroups or replaceGroups is called and new group information is available. More... | |
| pqPresetGroupsManager (QObject *p) | |
| Create a new groups manager. More... | |
| ~pqPresetGroupsManager () | |
| int | numberOfGroups () |
| Returns the number of groups the manager knows of. More... | |
| int | numberOfPresetsInGroup (const QString &groupName) |
| Returns the number of presets in the given group. More... | |
| int | presetRankInGroup (const QString &presetName, const QString &groupName) |
| Returns the rank (index) of the given preset in the given group. More... | |
| QList< QString > | groupNames () |
| Returns a list of the group names the manager knows of. More... | |
| QString | groupName (int i) |
| Returns the name of the ith group in the manager's list of groups. More... | |
| void | loadGroups (const QString &json) |
| Load groups from the given JSON string (for the format see the class documentation) and add the groups to the groups in the manager. More... | |
| void | replaceGroups (const QString &json) |
| Clears all groups in the manager and then loads groups from the given JSON string (see loadGroups). More... | |
A pqPresetGroupsManager is created by the pqPVApplicationCore and registered as a manager. To get it:
The group manager loads the groups of presets from a json file with this format:
Definition at line 91 of file pqPresetGroupsManager.h.
| pqPresetGroupsManager::pqPresetGroupsManager | ( | QObject * | p | ) |
Custom applications should use the one created by pqPVApplicationCore (see class description).
| pqPresetGroupsManager::~pqPresetGroupsManager | ( | ) |
| int pqPresetGroupsManager::numberOfGroups | ( | ) |
| int pqPresetGroupsManager::presetRankInGroup | ( | const QString & | presetName, |
| const QString & | groupName | ||
Returns -1 if the preset is not in the group (the preset dialog relies on this).
| QList<QString> pqPresetGroupsManager::groupNames | ( | ) |
| QString pqPresetGroupsManager::groupName | ( | int | i | ) |
| void pqPresetGroupsManager::loadGroups | ( | const QString & | json | ) |
This is an append operation so the groups already in the manager will not be removed. If the json string has a group with the same name as one already in the manager, then the color maps in that group will be appended to the existing group.
| void pqPresetGroupsManager::replaceGroups | ( | const QString & | json | ) |
This is an override operation instead of the append provided by loadGroups.
signal |
