pqPointPickingHelper is a helper class that is designed for use by subclasses of pqInteractivePropertyWidget (or others) that want to support using a shortcut key to pick a point on the surface mesh.
#include <pqPointPickingHelper.h>
Inherits QObject.
Definition at line 49 of file pqPointPickingHelper.h.
◆ pqPointPickingHelper()
| pqPointPickingHelper::pqPointPickingHelper |
const QKeySequence & |
keySequence, |
bool |
pick_on_mesh, |
QObject * |
parent = 0 |
◆ ~pqPointPickingHelper()
| pqPointPickingHelper::~pqPointPickingHelper |
◆ pickOnMesh()
| bool pqPointPickingHelper::pickOnMesh |
const |
Returns whether the helper will pick a point in the mesh or simply a point on the surface.
In other words, if pickOnMesh returns true, then the picked point will always be a point specified in the points that form the mesh.
Definition at line 64 of file pqPointPickingHelper.h.
◆ setView
| void pqPointPickingHelper::setView |
pqView * |
view | ) |
slot |
Set the view on which the pick is active.
We only support pqRenderView and subclasses currently.
◆ setShortcutEnabled
| void pqPointPickingHelper::setShortcutEnabled |
bool |
slot |
Enable/disable the pick point shortcut.
◆ pick
