pqParaViewMenuBuilders provides helper methods to build menus that are exactly as used by ParaView client.
#include <pqParaViewMenuBuilders.h>
| static void | buildFileMenu (QMenu &menu) |
| | Builds standard File menu. More...
| static void | buildEditMenu (QMenu &menu, pqPropertiesPanel *propertiesPanel=nullptr) |
| | Builds the standard Edit menu. More...
| static void | buildSourcesMenu (QMenu &menu, QMainWindow *mainWindow=0) |
| | Builds "Sources" menu. More...
| static void | buildFiltersMenu (QMenu &menu, QMainWindow *mainWindow=0, bool hideDisabled=false, bool quickLaunchable=true) |
| | Builds "Filters" menu. More...
| static void | buildExtractorsMenu (QMenu &menu, QMainWindow *mainWindow=nullptr, bool hideDisabled=false, bool quickLaunchable=true) |
| | Builds "Extractors" menu. More...
| static void | buildToolsMenu (QMenu &menu) |
| | Builds the "Tools" menu. More...
| static void | buildCatalystMenu (QMenu &menu) |
| | Builds the "Catalyst" menu. More...
| static void | buildViewMenu (QMenu &menu, QMainWindow &window) |
| | Builds the "View" menu. More...
| static void | buildMacrosMenu (QMenu &menu) |
| | Builds the "Macros" menu. More...
| static void | buildHelpMenu (QMenu &menu) |
| | Builds the help menu. More...
| static void | buildPipelineBrowserContextMenu (QMenu &menu, QMainWindow *window=nullptr) |
| | Builds the context menu shown over the pipeline browser for some common pipeline operations. More...
| static void | buildToolbars (QMainWindow &mainWindow) |
| | Builds and adds all standard ParaView toolbars. More...
Simply call the appropriate method with the menu as an argument, and it will be populated with actions and reactions for standard ParaView behavior.
Definition at line 49 of file pqParaViewMenuBuilders.h.
◆ buildFileMenu()
| static void pqParaViewMenuBuilders::buildFileMenu |
QMenu & |
menu | ) |
◆ buildEditMenu()
| static void pqParaViewMenuBuilders::buildEditMenu |
QMenu & |
menu, |
pqPropertiesPanel * |
propertiesPanel = nullptr |
◆ buildSourcesMenu()
| static void pqParaViewMenuBuilders::buildSourcesMenu |
QMenu & |
menu, |
QMainWindow * |
mainWindow = 0 |
If you want to automatically add toolbars for sources as requested in the configuration pass in a non-null main window.
◆ buildFiltersMenu()
| static void pqParaViewMenuBuilders::buildFiltersMenu |
QMenu & |
menu, |
QMainWindow * |
mainWindow = 0, |
bool |
hideDisabled = false, |
bool |
quickLaunchable = true |
If you want to automatically add toolbars for filters as requested in the configuration pass in a non-null main window. If you do not want to add the actions from the filters menu to quick launch maintained by pqApplicationCore (see pqPVApplicationCore::registerForQuicklaunch), then pass quickLaunchable == false.
◆ buildExtractorsMenu()
| static void pqParaViewMenuBuilders::buildExtractorsMenu |
QMenu & |
menu, |
QMainWindow * |
mainWindow = nullptr, |
bool |
bool |
◆ buildToolsMenu()
| static void pqParaViewMenuBuilders::buildToolsMenu |
QMenu & |
menu | ) |
◆ buildCatalystMenu()
| static void pqParaViewMenuBuilders::buildCatalystMenu |
QMenu & |
menu | ) |
◆ buildViewMenu()
| static void pqParaViewMenuBuilders::buildViewMenu |
QMenu & |
menu, |
QMainWindow & |
window |
◆ buildMacrosMenu()
| static void pqParaViewMenuBuilders::buildMacrosMenu |
QMenu & |
menu | ) |
This menu is automatically hidden is python support is not enabled.
◆ buildHelpMenu()
| static void pqParaViewMenuBuilders::buildHelpMenu |
QMenu & |
menu | ) |
◆ buildPipelineBrowserContextMenu()
| static void pqParaViewMenuBuilders::buildPipelineBrowserContextMenu |
QMenu & |
menu, |
QMainWindow * |
window = nullptr |
◆ buildToolbars()
| static void pqParaViewMenuBuilders::buildToolbars |
QMainWindow & |
mainWindow | ) |
