widget to show composite data hierarchy and controls its display properties.
#include <pqMultiBlockInspectorWidget.h>
Inherits QWidget.
pqMultiBlockInspectorWidget is a QWidget that is used to allow user to view a composite dataset hierarchy. It also supports viewing and modifying display properties for the composite dataset.
pqMultiBlockInspectorWidget monitors active pqActiveObjects to track active port and view by default. To not have the pqMultiBlockInspectorWidget track the active objects, you can pass autotracking as false to the constructor. In that case, the port and view to use can be set using setOutputPort and setView.
- See also
- pqCompositeDataInformationTreeModel
Definition at line 62 of file pqMultiBlockInspectorWidget.h.
◆ pqMultiBlockInspectorWidget()
| pqMultiBlockInspectorWidget::pqMultiBlockInspectorWidget |
QWidget * |
parent = nullptr, |
Qt::WindowFlags |
f = Qt::WindowFlags(), |
bool |
autotracking = true |
◆ ~pqMultiBlockInspectorWidget()
| pqMultiBlockInspectorWidget::~pqMultiBlockInspectorWidget |
◆ isAutoTrackingEnabled()
| bool pqMultiBlockInspectorWidget::isAutoTrackingEnabled |
const |
◆ blockVisibilities()
| QList<QVariant> pqMultiBlockInspectorWidget::blockVisibilities |
const |
Get/Set block visibilities.
The value is a list of QVariants in pairs where 1st value is the block index and 2nd value is its visibility state.
◆ setBlockVisibilities()
| void pqMultiBlockInspectorWidget::setBlockVisibilities |
const QList< QVariant > & |
bvs | ) |
◆ visibleBlocks()
| QList<QVariant> pqMultiBlockInspectorWidget::visibleBlocks |
const |
Get/Set the visible blocks.
Unlike blockVisibilities, this is compact list of visible blocks given the current hierarchy.
◆ setVisibleBlocks()
| void pqMultiBlockInspectorWidget::setVisibleBlocks |
vbs | ) |
◆ blockColors()
| QList<QVariant> pqMultiBlockInspectorWidget::blockColors |
const |
Get/Set block colors.
The value is a list of QVariants in 4-tuples where 1st value is the block color and the next 3 values are rgb color in each in range [0, 1.0].
◆ setBlockColors()
| void pqMultiBlockInspectorWidget::setBlockColors |
bcs | ) |
◆ blockOpacities()
| QList<QVariant> pqMultiBlockInspectorWidget::blockOpacities |
const |
Get/Set block opacities.
The value is a list of QVariants in pairs where 1st value is the block color and the 2nd value is opacity in range [0, 1.0].
◆ setBlockOpacities()
| void pqMultiBlockInspectorWidget::setBlockOpacities |
bos | ) |
◆ outputPort()
| pqOutputPort* pqMultiBlockInspectorWidget::outputPort |
const |
Get the current output port.
The widget shows the composite tree for the data produced by at this port.
◆ view()
| pqView* pqMultiBlockInspectorWidget::view |
const |
◆ representation()
Get the current representation.
◆ setOutputPort
| void pqMultiBlockInspectorWidget::setOutputPort |
pqOutputPort * |
port | ) |
slot |
When auto-tracking is disabled, sets the port to use to get the data information for this widget to show.
Calling this method when auto-tracking is disabled will raise a debug message and has no effect.
◆ setView
| void pqMultiBlockInspectorWidget::setView |
pqView * |
view | ) |
slot |
When auto-tracking is disabled, sets the view to use.
If outputPort has a representation is this view with block-coloring/opacity support, then controls for coloring/opacity will be presented to the user.
◆ blockVisibilitiesChanged
| void pqMultiBlockInspectorWidget::blockVisibilitiesChanged |
signal |
◆ blockColorsChanged
| void pqMultiBlockInspectorWidget::blockColorsChanged |
signal |
◆ blockOpacitiesChanged
| void pqMultiBlockInspectorWidget::blockOpacitiesChanged |
signal |
◆ requestRender
| void pqMultiBlockInspectorWidget::requestRender |
signal |
◆ blockVisibilities
readwrite |
◆ blockColors
readwrite |
◆ blockOpacities
readwrite |
◆ visibleBlocks
readwrite |
