pqFindDataSelectionDisplayFrame is designed to be used by pqFindDataDialog.
#include <pqFindDataSelectionDisplayFrame.h>
Inherits QWidget.
pqFindDataDialog uses this class to allow controlling the display properties for the selection in the active view. Currently, it only support controlling the display properties for the selection in a render view. It monitors the active selection by tracking pqSelectionManager as well as the active view by tracking pqActiveObjects singleton.
Definition at line 49 of file pqFindDataSelectionDisplayFrame.h.
◆ pqFindDataSelectionDisplayFrame()
| pqFindDataSelectionDisplayFrame::pqFindDataSelectionDisplayFrame |
QWidget * |
parent = nullptr, |
Qt::WindowFlags |
f = Qt::WindowFlags{} |
◆ ~pqFindDataSelectionDisplayFrame()
| pqFindDataSelectionDisplayFrame::~pqFindDataSelectionDisplayFrame |
◆ setUseVerticalLayout()
| void pqFindDataSelectionDisplayFrame::setUseVerticalLayout |
bool |
pqFindDataSelectionDisplayFrame can be made to lay itself out in a more vertical fashion rather than the default, horizontal layout.
To use a vertical layout, use this method.
◆ useVerticalLayout()
| bool pqFindDataSelectionDisplayFrame::useVerticalLayout |
const |
◆ setSelectedPort
| void pqFindDataSelectionDisplayFrame::setSelectedPort |
pqOutputPort * |
slot |
Set the output port that is currently selected for which we are controlling the selection display properties.
◆ setView
| void pqFindDataSelectionDisplayFrame::setView |
pqView * |
slot |
set the view in which we are controlling the selection display properties.
label properties as well as which array to label with affect only the active view.
◆ pqInternals
◆ useVerticalLayout
readwrite |
