pqDisplayColorWidget is a widget that can be used to select the array to with for representations (also known as displays). More...
#include <pqDisplayColorWidget.h>
Inherits QWidget.
| typedef QPair< int, QString > | ValueType |
Public Slots | |
| void | setRepresentation (pqDataRepresentation *display) |
| Set the representation to control the scalar coloring properties on. More... | |
Signals | |
| void | arraySelectionChanged () |
| fired to indicate the array-name changed. More... | |
| pqDisplayColorWidget (QWidget *parent=0) | |
| ~pqDisplayColorWidget () override | |
| ValueType | arraySelection () const |
| Get/Set the array name as pair (association-number, arrayname). More... | |
| QString | getCurrentText () const |
| int | componentNumber () const |
| Get/Set the component number (-1 == magnitude). More... | |
| vtkSMViewProxy * | viewProxy () const |
| Returns the view proxy corresponding to the set representation, if any. More... | |
| void | setArraySelection (const ValueType &) |
| Update the UI to show the selected array. More... | |
| void | setComponentNumber (int) |
| Update the UI to show the selected component. More... | |
Friends | |
| class | PropertyLinksConnection |
It comprises of two combo-boxes, one for the array name, and another for component number. To use, set the representation using setRepresentation(..). If the representation has appropriate properties, this widget will allow users to select the array name.
Definition at line 55 of file pqDisplayColorWidget.h.
| typedef QPair<int, QString> pqDisplayColorWidget::ValueType |
Definition at line 61 of file pqDisplayColorWidget.h.
| pqDisplayColorWidget::pqDisplayColorWidget | ( | QWidget * | parent = 0 | ) |
| ValueType pqDisplayColorWidget::arraySelection | ( | ) | const |
Definition at line 71 of file pqDisplayColorWidget.h.
| int pqDisplayColorWidget::componentNumber | ( | ) | const |
| vtkSMViewProxy* pqDisplayColorWidget::viewProxy | ( | ) | const |
signal |
slot |
friend |
Definition at line 172 of file pqDisplayColorWidget.h.
