pqColorAnnotationsWidget is used to edit annotations and colors More...
#include <pqColorAnnotationsWidget.h>
Inherits QWidget.
Signals | |
| void | annotationsChanged () |
| Fired when the annotations are changed. More... | |
| void | indexedColorsChanged () |
| Fired when the indexed colors are changed. More... | |
| void | indexedOpacitiesChanged () |
| Fired when the indexed opacities are changed. More... | |
| void | visibilitiesChanged () |
| Fired when the visibilities are changed. More... | |
| void | opacityMappingChanged () |
| Fired when the opacity mapping status is changed. More... | |
| void | presetChanged (const QString &name) |
| Fired when a new preset is applied. More... | |
| void | selectionChanged (const QItemSelection &, const QItemSelection &) |
| Fired when the currently focused item changed. More... | |
| pqColorAnnotationsWidget (QWidget *parent=0) | |
| ~pqColorAnnotationsWidget () override | |
| void | setLookupTableProxy (vtkSMProxy *proxy) |
| void | applyPreset (const char *presetName) |
| Apply a color preset using its name. More... | |
| void | indexedLookupStateUpdated (bool indexed) |
| Ensures that the table for indexedColors are shown only when this is set to true. More... | |
| bool | addActiveAnnotations (bool force) |
| Use active representation to create annotations. More... | |
| QModelIndex | currentIndex () |
| Return current model index from table. More... | |
| QModelIndexList | selectedIndexes () |
| Return the selected indexes. More... | |
| void | setAnnotationsModel (pqAnnotationsModel *model) |
| Set the annotionModel on the underlying table. More... | |
| void | setSupportsReorder (bool reorder) |
| Set reordering support on the table. More... | |
| void | sort (int column, Qt::SortOrder order=Qt::AscendingOrder) |
| Sort the underlying proxy model. More... | |
| void | allowsUserDefinedValues (bool allow) |
| Show/Hide relevant widgets. More... | |
| void | allowsRegexpMatching (bool allow) |
| Setup ChooseColor dialog. More... | |
| void | enablePresets (bool enable) |
| void | supportsVisibilityCheck (bool val) |
| Show/Hide the Visibility column. More... | |
| void | supportsOpacityMapping (bool val) |
| Show/Hide the EnableOpacityMapping button. More... | |
| void | setColumnVisibility (pqAnnotationsModel::ColumnRoles col, bool visible) |
| Show/Hide given column. More... | |
| QString | currentAnnotationValue () |
| Get the current annotation value. More... | |
| QStringList | selectedAnnotations () |
| Get the selected annotations values. More... | |
| void | setSelectedAnnotations (const QStringList &annotations) |
| bool | presetLoadAnnotations () |
| Get if annotations should be loaded with the preset. More... | |
| QRegularExpression | presetRegularExpression () |
| Get the regular expression to use to apply the preset. More... | |
| QList< QVariant > | annotations () const |
| Get/Set the annotations. More... | |
| void | setAnnotations (const QList< QVariant > &) |
| QList< QVariant > | indexedColors () const |
| Get/Set the indexed colors. More... | |
| void | setIndexedColors (const QList< QVariant > &) |
| QList< QVariant > | indexedOpacities () const |
| Get/Set the indexed opacities. More... | |
| void | setIndexedOpacities (const QList< QVariant > &) |
| QList< QVariant > | visibilities () const |
| Get/Set the indexed visibilities. More... | |
| void | setVisibilities (const QList< QVariant > &) |
| QVariant | opacityMapping () const |
| Get/Set the opacity mapping status. More... | |
| void | setOpacityMapping (const QVariant &) |
| const char * | currentPresetName () |
| Get / Set the name of the current preset in use. More... | |
| void | setCurrentPresetName (const char *name) |
| bool | addActiveAnnotationsFromVisibleSources (bool force) |
| Create annotations from visibles part of the active representation. More... | |
Definition at line 49 of file pqColorAnnotationsWidget.h.
| pqColorAnnotationsWidget::pqColorAnnotationsWidget | ( | QWidget * | parent = 0 | ) |
| void pqColorAnnotationsWidget::setLookupTableProxy | ( | vtkSMProxy * | proxy | ) |
| QList<QVariant> pqColorAnnotationsWidget::annotations | ( | ) | const |
This is a list generated by flattening 2-tuples where 1st value is the annotated value and second is the annotation text.
| void pqColorAnnotationsWidget::setAnnotations | ( | const QList< QVariant > & | ) |
| QList<QVariant> pqColorAnnotationsWidget::indexedColors | ( | ) | const |
This is a list generated by flattening 3-tuples (r,g,b).
| void pqColorAnnotationsWidget::setIndexedColors | ( | const QList< QVariant > & | ) |
| QList<QVariant> pqColorAnnotationsWidget::indexedOpacities | ( | ) | const |
| void pqColorAnnotationsWidget::setIndexedOpacities | ( | const QList< QVariant > & | ) |
| QList<QVariant> pqColorAnnotationsWidget::visibilities | ( | ) | const |
| void pqColorAnnotationsWidget::setVisibilities | ( | const QList< QVariant > & | ) |
| QVariant pqColorAnnotationsWidget::opacityMapping | ( | ) | const |
| void pqColorAnnotationsWidget::setOpacityMapping | ( | const QVariant & | ) |
| void pqColorAnnotationsWidget::applyPreset | ( | const char * | presetName | ) |
| void pqColorAnnotationsWidget::indexedLookupStateUpdated | ( | bool | indexed | ) |
| bool pqColorAnnotationsWidget::addActiveAnnotations | ( | bool | force | ) |
| QModelIndex pqColorAnnotationsWidget::currentIndex | ( | ) |
Uses QSortFilterProxyModel if exists.
| QModelIndexList pqColorAnnotationsWidget::selectedIndexes | ( | ) |
| void pqColorAnnotationsWidget::setAnnotationsModel | ( | pqAnnotationsModel * | model | ) |
| void pqColorAnnotationsWidget::setSupportsReorder | ( | bool | reorder | ) |
| void pqColorAnnotationsWidget::sort | ( | int | column, |
| Qt::SortOrder | order = Qt::AscendingOrder |
| void pqColorAnnotationsWidget::allowsUserDefinedValues | ( | bool | allow | ) |
If allow is false, hide the buttons that add/remove lines.
| void pqColorAnnotationsWidget::allowsRegexpMatching | ( | bool | allow | ) |
If allow is true, add a line edit to specify a regexp to do the matching between data values and preset. Intended to be used for series preset.
| void pqColorAnnotationsWidget::enablePresets | ( | bool | enable | ) |
If enable is false, hide the buttons that save / load presets.
| void pqColorAnnotationsWidget::supportsVisibilityCheck | ( | bool | val | ) |
| void pqColorAnnotationsWidget::supportsOpacityMapping | ( | bool | val | ) |
| void pqColorAnnotationsWidget::setColumnVisibility | ( | pqAnnotationsModel::ColumnRoles | col, |
| bool | visible | ||
| const char* pqColorAnnotationsWidget::currentPresetName | ( | ) |
| void pqColorAnnotationsWidget::setCurrentPresetName | ( | const char * | name | ) |
| QString pqColorAnnotationsWidget::currentAnnotationValue | ( | ) |
| QStringList pqColorAnnotationsWidget::selectedAnnotations | ( | ) |
| void pqColorAnnotationsWidget::setSelectedAnnotations | ( | const QStringList & | annotations | ) |
| bool pqColorAnnotationsWidget::presetLoadAnnotations | ( | ) |
| QRegularExpression pqColorAnnotationsWidget::presetRegularExpression | ( | ) |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
