pqChangeInputDialog is the dialog used to allow the user to change/set the input(s) for a filter.
#include <pqChangeInputDialog.h>
Inherits QDialog.
It does not actually change the inputs, that is left for the caller to do when the exec() returns with with QDialog::Accepted.
Definition at line 48 of file pqChangeInputDialog.h.
◆ pqChangeInputDialog()
| pqChangeInputDialog::pqChangeInputDialog |
vtkSMProxy * |
filterProxy, |
QWidget * |
parent = 0 |
Constructor.
filterProxy is the proxy for the filter whose inputs are being changed using this dialog. The filterProxy can be a prototype proxy when using this dialog to set up the inputs during filter creation. The values from the input properties of the filterProxy are used as the default values shown by this dialog.
◆ ~pqChangeInputDialog()
| pqChangeInputDialog::~pqChangeInputDialog |
◆ selectedInputs()
| const QMap<QString, QList<pqOutputPort*> >& pqChangeInputDialog::selectedInputs |
const |
Returns the map of selected inputs.
The key in this map is the name of the input property, while the values in the map are the list of output ports that are chosen to be the input for that property. This list will contain at most 1 item, when the input property indicates that it can accept only 1 value.
◆ inputPortToggled
| void pqChangeInputDialog::inputPortToggled |
bool |
protectedslot |
◆ selectionChanged
| void pqChangeInputDialog::selectionChanged |
protectedslot |
◆ buildPortWidgets()
| void pqChangeInputDialog::buildPortWidgets |
