pqCameraKeyFrameWidget is the widget that is shown to edit the value of a single camera key frame.
#include <pqCameraKeyFrameWidget.h>
Inherits QWidget.
This class is based on pqCameraWidget and hence has sections of code borrowed from there.
Definition at line 46 of file pqCameraKeyFrameWidget.h.
◆ pqCameraKeyFrameWidget()
| pqCameraKeyFrameWidget::pqCameraKeyFrameWidget |
QWidget * |
parent = 0 | ) |
◆ ~pqCameraKeyFrameWidget()
| pqCameraKeyFrameWidget::~pqCameraKeyFrameWidget |
◆ usePathBasedMode()
| bool pqCameraKeyFrameWidget::usePathBasedMode |
const |
◆ useCurrentCamera
| void pqCameraKeyFrameWidget::useCurrentCamera |
signal |
Fired when user requests the use of the current camera as the value for the key frame.
◆ updateCurrentCamera
| void pqCameraKeyFrameWidget::updateCurrentCamera |
signal |
◆ initializeUsingKeyFrame
| void pqCameraKeyFrameWidget::initializeUsingKeyFrame |
vtkSMProxy * |
keyframeProxy | ) |
slot |
Initialize the widget using the values from the key frame proxy.
◆ initializeUsingCamera
| void pqCameraKeyFrameWidget::initializeUsingCamera |
vtkCamera * |
camera | ) |
slot |
Initialize the widget using the camera.
◆ applyToCamera
| void pqCameraKeyFrameWidget::applyToCamera |
vtkCamera * |
camera | ) |
slot |
Initialize the camera using the widget values.
◆ setUsePathBasedMode
| void pqCameraKeyFrameWidget::setUsePathBasedMode |
bool |
slot |
The camera keyframes have 2 modes either interpolate vtkCamera's using the camera interpolator or use path-based.
This mode is not defined on per-keyframe basis, but on the entire animation track. Hence, we provide this slot to choose which mode should the widget operate in.
◆ saveToKeyFrame
| void pqCameraKeyFrameWidget::saveToKeyFrame |
vtkSMProxy * |
keyframeProxy | ) |
slot |
Write the user chosen values for this key frame to the proxy.
◆ showEvent()
| void pqCameraKeyFrameWidget::showEvent |
QShowEvent * |
◆ hideEvent()
| void pqCameraKeyFrameWidget::hideEvent |
QHideEvent * |
