pqAnimationTimeWidget is a widget that can be used to show/set the current animation time. More...
#include <pqAnimationTimeWidget.h>
Inherits QWidget.
| using | RealNumberNotation = pqDoubleLineEdit::RealNumberNotation |
Public Slots | |
| void | setAnimationScene (vtkSMProxy *animationScene) |
| Set the animation scene proxy which is reflected/controlled by this widget. More... | |
| void | setNotation (RealNumberNotation _notation) |
| Set the notation used to display the number. More... | |
| void | setPrecision (int precision) |
| Set the precision used to display the number. More... | |
Signals | |
| void | timeValueChanged () |
| void | playModeChanged () |
| void | dummySignal () |
| pqAnimationTimeWidget (QWidget *parent=0) | |
| ~pqAnimationTimeWidget () override | |
| vtkSMProxy * | animationScene () const |
| Provides access to the animation scene proxy currently controlled/reflected by this widget. More... | |
| RealNumberNotation | notation () const |
| Return the notation used to display the number. More... | |
| int | precision () const |
| Return the precision used to display the number. More... | |
| void | setTimestepValues (const QList< QVariant > &list) |
| Get/Set the list of timestep. More... | |
| const QList< QVariant > & | timestepValues () const |
| void | setTimeValue (double time) |
| Get/set the current time value. More... | |
| double | timeValue () const |
| void | setPlayMode (const QString &mode) |
| Get/set the animation playback mode. More... | |
| QString | playMode () const |
| void | setPlayModeReadOnly (bool val) |
| Get/set whether the user should be able to change the animation play mode using this widget. More... | |
| bool | playModeReadOnly () const |
| void | setTimeLabel (const QString &val) |
| Get/set the label text to use for the "time" parameter. More... | |
| QString | timeLabel () const |
| void | setTimePrecision (int) |
| int | timePrecision () const |
| void | setTimeNotation (const QChar &val) |
| QChar | timeNotation () const |
| void | setTimeStepCount (int count) |
| int | timeStepCount () const |
Properties | |
| double | timeValue |
| QString | playMode |
| bool | playModeReadOnly |
| QString | timeLabel |
| QList< QVariant > | timestepValues |
The widget allow the user to do the following:
Definition at line 60 of file pqAnimationTimeWidget.h.
Definition at line 76 of file pqAnimationTimeWidget.h.
| pqAnimationTimeWidget::pqAnimationTimeWidget | ( | QWidget * | parent = 0 | ) |
| vtkSMProxy* pqAnimationTimeWidget::animationScene | ( | ) | const |
| void pqAnimationTimeWidget::setTimestepValues | ( | const QList< QVariant > & | list | ) |
QList<QVariant> is a list of variants convertible to double.
| const QList<QVariant>& pqAnimationTimeWidget::timestepValues | ( | ) | const |
| void pqAnimationTimeWidget::setTimeValue | ( | double | time | ) |
| double pqAnimationTimeWidget::timeValue | ( | ) | const |
| RealNumberNotation pqAnimationTimeWidget::notation | ( | ) | const |
| int pqAnimationTimeWidget::precision | ( | ) | const |
| void pqAnimationTimeWidget::setPlayMode | ( | const QString & | mode | ) |
| QString pqAnimationTimeWidget::playMode | ( | ) | const |
| void pqAnimationTimeWidget::setPlayModeReadOnly | ( | bool | val | ) |
| bool pqAnimationTimeWidget::playModeReadOnly | ( | ) | const |
| void pqAnimationTimeWidget::setTimeLabel | ( | const QString & | val | ) |
| QString pqAnimationTimeWidget::timeLabel | ( | ) | const |
| void pqAnimationTimeWidget::setTimePrecision | ( | int | ) |
Use setPrecision and setNotation instead.
| int pqAnimationTimeWidget::timePrecision | ( | ) | const |
| void pqAnimationTimeWidget::setTimeNotation | ( | const QChar & | val | ) |
| QChar pqAnimationTimeWidget::timeNotation | ( | ) | const |
| void pqAnimationTimeWidget::setTimeStepCount | ( | int | count | ) |
No longer used. Use setTimestepValues instead to provide the timesteps explicitly.
| int pqAnimationTimeWidget::timeStepCount | ( | ) | const |
signal |
signal |
signal |
slot |
slot |
slot |
readwrite |
Definition at line 64 of file pqAnimationTimeWidget.h.
readwrite |
Definition at line 65 of file pqAnimationTimeWidget.h.
readwrite |
Definition at line 66 of file pqAnimationTimeWidget.h.
readwrite |
Definition at line 67 of file pqAnimationTimeWidget.h.
readwrite |
Definition at line 68 of file pqAnimationTimeWidget.h.
