pqAnimatablePropertiesComboBox is a combo box that can list the animatable properties of any proxy.
#include <pqAnimatablePropertiesComboBox.h>
Inherits QComboBox.
Definition at line 44 of file pqAnimatablePropertiesComboBox.h.
◆ pqAnimatablePropertiesComboBox()
| pqAnimatablePropertiesComboBox::pqAnimatablePropertiesComboBox |
QWidget * |
parent = 0 | ) |
◆ ~pqAnimatablePropertiesComboBox()
| pqAnimatablePropertiesComboBox::~pqAnimatablePropertiesComboBox |
◆ source()
| vtkSMProxy* pqAnimatablePropertiesComboBox::source |
const |
Returns the source whose properties are currently being listed, if any.
◆ getCurrentProxy()
| vtkSMProxy* pqAnimatablePropertiesComboBox::getCurrentProxy |
const |
◆ getCurrentPropertyName()
| QString pqAnimatablePropertiesComboBox::getCurrentPropertyName |
const |
◆ getCurrentIndex()
| int pqAnimatablePropertiesComboBox::getCurrentIndex |
const |
◆ getCollapseVectors()
| bool pqAnimatablePropertiesComboBox::getCollapseVectors |
const |
If true, vector properties will have a single entry.
If false, each vector component will be displayed separately. Default: false.
◆ getVectorSizeFilter()
| int pqAnimatablePropertiesComboBox::getVectorSizeFilter |
const |
This class can filter the displayed properties to only show those with a specified number of components.
Returns the current filter settings. -1 means no filtering (default).
◆ setUseBlankEntry()
| void pqAnimatablePropertiesComboBox::setUseBlankEntry |
bool |
b | ) |
Sometimes, we want the combo to show a empty field that does not represent any property.
Set this to true to use such a field.
Definition at line 79 of file pqAnimatablePropertiesComboBox.h.
◆ setSource
| void pqAnimatablePropertiesComboBox::setSource |
vtkSMProxy * |
proxy | ) |
slot |
Set the source whose properties this widget should list.
If source is null, the widget gets disabled.
◆ setSourceWithoutProperties
| void pqAnimatablePropertiesComboBox::setSourceWithoutProperties |
vtkSMProxy * |
proxy | ) |
slot |
Set source without calling buildPropertyList() internally.
Thus the user will explicitly call addSMProperty to add properties.
◆ setCollapseVectors
| void pqAnimatablePropertiesComboBox::setCollapseVectors |
bool |
val | ) |
slot |
◆ setVectorSizeFilter
| void pqAnimatablePropertiesComboBox::setVectorSizeFilter |
int |
size | ) |
slot |
Set the current filter setting. -1 means no filtering (default).
◆ addSMProperty
| void pqAnimatablePropertiesComboBox::addSMProperty |
const QString & |
label, |
const QString & |
propertyname, |
int |
index |
slot |
Add a property to the widget.
◆ buildPropertyList
| void pqAnimatablePropertiesComboBox::buildPropertyList |
protectedslot |
Builds the property list.
