Data is complex! As simulations have grown in complexity and capabilities, the datasets they produce have also become complex. It is not uncommon to encounter datasets comprising of multiple chunks or blocks e.g. Exodus, CGNS. The blocks may also have relationships between them e.g. to describe an assembly, or block properties like materials. When such relationships are available in the dataset, it is indeed useful to present this information to the users so that they can choose to load blocks in multiple ways. Subset inclusion lattice or SIL is the mechanism available to ParaView readers to describe this information.
Currently, SIL is only used by readers to describe relations among blocks to enable selecting of blocks to reader. The blocks need not corresponding to actual data blocks in the file but in practice, they often do. If future, the plan is to provide access to the SIL along with composite dataset produced by the reader.
A reader or a data source that wants to expose an ability to select blocks to read should generate a SIL. While a SIL can include information of data arrays such as point data arrays or cell data arrays available in the file, currently we keep that separate due to existing conventions.
In vtkAlgorithm::RequestInformation, every time the filename changes, you read metadata from the file to build a SIL (vtkSubsetInclusionLattice). vtkSubsetInclusionLattice provides API to initialize the SIL and then add nodes with names in a tree structure with parent-child relationships. Directed links between subtrees can also be added – these are called cross links (vtkSubsetInclusionLattice::AddCrossLink).
The top-level nodes i.e. nodes with parent 0 are treated as classifications or categories e.g. Assembly, Material etc. There are no other special requirements on what the nodes should be or how the relationships are defined. Typically, the first category subtree is native structure for the file format. For example, in CGNS, data is laid out in a tree-like structure comprising of bases, zones, and patches. Hence the CGNS reader (vtkCGNSReader) chose to put this structure under the first Hierarchy subtree. The structure reflects the file format layout.
/Hierarchy/
Base1/
Zone1/
Grid
Patch0
Patch1
Zone2/
Grid
Patch2
Base2/
The zones and patches have an attribute called family name. The family is often used to describe additional characteristics of the zone or patch e.g boundary-condition-1, side-wall, etc. To allow the ability to select using family names, vtkCGNSReader added a second category subtree for Families.
/Families/
Family1
Family2
To link family names with nodes under the Hierarchy sub-tree, we use cross links. Thus there's a cross link from each family name to the zone, grid or patch nodes under the Hierarchy sub-tree.
An example CGNS SIL is as follows:
/Hierarchy/
base/
blk-1/
Grid
bc-1-wall
bc-2-inflow
bc-3-outflow
bc-4-symm-y
bc-5-symm-z1
bc-6-symm-z2
/Families/
bc-1-wall
(cross-link: Hierarchy/base/blk-1/bc-1-wall)
bc-2-inflow
(cross-link: Hierarchy/base/blk-1/bc-2-inflow)
bc-3-outflow
(cross-link: Hierarchy/base/blk-1/bc-3-outflow)
bc-4-symm-y
(cross-link: Hierarchy/base/blk-1/bc-4-symm-y)
bc-5-symm-z1
(cross-link: Hierarchy/base/blk-1/bc-5-symm-z1)
bc-6-symm-z2
(cross-link: Hierarchy/base/blk-1/bc-6-symm-z2)
/Grids/
base/
blk-1
(cross-link: Hierarchy/base/blk-1/Grid)
/Patches/
base/
blk-1
Now, when user selects a specific family, all nodes linked to it under the Hierarchy subtree also need to be selected. vtkSubsetInclusionLattice manages this internally.
While vtkSubsetInclusionLattice has API to select/deselect nodes by node ids as well as user-friendly paths, it's inconvenient for a CGNS user to know how a base or family is to be named. Hence vtkCGNSReader defines a subclass of vtkSubsetInclusionLattice called vtkCGNSSubsetInclusionLattice and uses it to store the SIL. vtkCGNSSubsetInclusionLattice has CGNS-friendly selection API e.g. vtkCGNSSubsetInclusionLattice::SelectBase(basename), vtkCGNSSubsetInclusionLattice::SelectFamily(familyname) etc. Readers should provide such subclasses as needed to make it easier on the users. At the same time, the reader can expose API itself that simply forwards to the internal SIL e.g. vtkCGNSReader::SetBaseArrayStatus simply calls vtkCGNSSubsetInclusionLattice::SelectBase or vtkCGNSSubsetInclusionLattice::DeselectBase on the SIL.
Once the SIL has been built, it should be placed in the output information using vtkSubsetInclusionLattice::SUBSET_INCLUSION_LATTICE() key.
A typical RequestInformation implementation will have the following form:
Readers that support a SIL for block selection need to expose the SIL so that users can use it to make selections. Typically, you'd expose the SIL by a simple Get method.
For readers that define a subclass, you would want to change the GetSIL signature to return an appropriate type rather than the generic vtkSubsetInclusionLattice.
Additionally, readers should expose selection API for clearing selections and selecting/deselecting nodes by path. This is useful not only for the users to make easy selections, but also when defining ParaView Server-Manager configuration XML.
The names of these methods need not be the same as shown in these snippets. You are free to choose whatever naming scheme that makes most sense for your reader.
In a typical scenario, the user uses the reader as follows:
In practice, however, the user may call the Select/Deselect API before calling vtkAlgorithm::UpdateInformation. To support this use-case, the SIL needs to preserve selection state for nodes even before the structure has been defined. This is currently supported by making Select/Deselect calls automatically add nodes at the specified path if they don't exist. That combined with the RequestInformation ensuring that selection state is preserved even after the SIL has been reconstructed address this use-case.
An important step to making SIL useful in a reader is for the reader to use the SIL to decide which blocks are selected. This simply means that in RequestData methond for the reader where it reads blocks, it should check with the SIL, using vtkSubsetInclusionLattice::GetSelectionState method or a convenient variant provided by the subclass (e.g. vtkCGNSSubsetInclusionLattice::ReadGridForZone).
Now that the reader supports SIL-based block selection, we need to expose it in the ParaView UI. This is done by adding the following set of properties.
The key is to use the vtkSMSubsetInclusionLatticeDomain for the block selection property. The Properties panel will use pqSubsetInclusionLatticeWidget and pqSubsetInclusionLatticeTreeModel to render the vtkSubsetInclusionLattice in a Qt widget.
The concept of subset inclusion lattice or SIL comes from VisIt. The implementation, however, is independent of VisIt and there is no expectation of compatibility, explicit or implied.
