Tree model using a vtkSubsetInclusionLattice.
#include <pqSubsetInclusionLatticeTreeModel.h>
Inherits QAbstractItemModel.
pqSubsetInclusionLatticeTreeModel is QAbstractItemModel implementation for vtkSubsetInclusionLattice. It exposes a tree-model using parent-child relationships defined among vtkSubsetInclusionLattice nodes. Cross links are ignored.
pqSubsetInclusionLatticeTreeModel is given a vtkSubsetInclusionLattice to model itself after. Since vtkSubsetInclusionLattice provides API to track and update selection states, this class simply uses vtkSubsetInclusionLattice to store it. However, to avoid modifying the instance passed in to setSubsetInclusionLattice, this class creates an internal deep copy and uses that to modify and track selection states.
- Note
- pqSubsetInclusionLatticeTreeModel will eventually replace pqSILModel after all readers have been updated to use vtkSubsetInclusionLattice rather that the vtkGraph-based SIL.
Definition at line 63 of file pqSubsetInclusionLatticeTreeModel.h.
◆ pqSubsetInclusionLatticeTreeModel()
| pqSubsetInclusionLatticeTreeModel::pqSubsetInclusionLatticeTreeModel |
QObject * |
parent = nullptr | ) |
◆ ~pqSubsetInclusionLatticeTreeModel()
| virtual pqSubsetInclusionLatticeTreeModel::~pqSubsetInclusionLatticeTreeModel |
◆ setSubsetInclusionLattice()
Get/Set the vtkSubsetInclusionLattice.
This class observes the instance passed, thus the model will continue to reflect the state for the SIL. sil is treated as constant i.e. no methods that modify its structure or selection state are called.
◆ subsetInclusionLattice()
◆ selection()
| QList<QVariant> pqSubsetInclusionLatticeTreeModel::selection |
const |
Returns the list of nodes that were selected.
◆ setSelection()
| void pqSubsetInclusionLatticeTreeModel::setSelection |
const QList< QVariant > & |
sel | ) |
◆ columnCount()
| int pqSubsetInclusionLatticeTreeModel::columnCount |
const QModelIndex & |
parent = QModelIndex() | ) |
const |
QAbstractItemModel interface implementation.
◆ rowCount()
| int pqSubsetInclusionLatticeTreeModel::rowCount |
const |
◆ index()
| QModelIndex pqSubsetInclusionLatticeTreeModel::index |
int |
row, |
int |
column, |
| const |
◆ parent()
| QModelIndex pqSubsetInclusionLatticeTreeModel::parent |
index = QModelIndex() | ) |
const |
◆ data()
| QVariant pqSubsetInclusionLatticeTreeModel::data |
index, |
int |
role |
| const |
◆ flags()
| Qt::ItemFlags pqSubsetInclusionLatticeTreeModel::flags |
index | ) |
const |
◆ setData()
| bool pqSubsetInclusionLatticeTreeModel::setData |
index, |
const QVariant & |
value, |
int |
role |
◆ selectionModified
| void pqSubsetInclusionLatticeTreeModel::selectionModified |
signal |
◆ silSelectionModified()
| void pqSubsetInclusionLatticeTreeModel::silSelectionModified |
vtkObject * |
unsigned |
long, |
void * |
◆ silStructureModified()
| void pqSubsetInclusionLatticeTreeModel::silStructureModified |
◆ indexForNode()
| QModelIndex pqSubsetInclusionLatticeTreeModel::indexForNode |
int |
node | ) |
const |
◆ selection
readwrite |
