| int | SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| | Update self based on the "unchecked" values of all required properties. More...
| | Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| | vtkSMRegistrationNamesDomain () |
| | ~vtkSMRegistrationNamesDomain () override |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| | vtkSMDomain () |
| void | DomainModified () |
| void | InvokeModified () |
| virtual void | ChildSaveState (vtkPVXMLElement *domainElement) |
| | vtkSMSessionObject () |
| | vtkSMObject () |
| | vtkObject () |
| | vtkObjectBase () |
domain to set default value for a property using proxy registration names
vtkSMRegistrationNamesDomain can be used for string-vector property to initialize it with registration names for proxies in the required property named "Proxies".
For example
<SourceProxy name="GroupDataSets" ...>
<InputProperty clean_command="RemoveAllInputs"
command="AddInputConnection"
multiple_input="1"
name="Input">
</InputProperty>
<StringVectorProperty name="BlockNames"
command="SetInputName"
number_of_elements_per_command="1"
repeat_command="1"
use_index="1"
clean_command="ClearInputNames">
<Documentation>
Specify names to use for each input.
</Documentation>
<RegistrationNamesDomain name="names_list" registration_group="sources">
<RequiredProperties>
<Property name="Input" function="Proxies" />
</RequiredProperties>
</RegistrationNamesDomain>
</StringVectorProperty>
</SourceProxy>
Definition at line 48 of file vtkSMRegistrationNamesDomain.h.
