Classes | Public Types | Public Member Functions | Static Public Member Functions | Protected Member Functions | Protected Attributes | List of all members
vtkSMRangeDomainTemplate< T > Class Template Reference
superclass for type-specific range domains i.e. More...
#include <vtkSMRangeDomainTemplate.h>
Inheritance diagram for vtkSMRangeDomainTemplate< T >:
Collaboration diagram for vtkSMRangeDomainTemplate< T >:
struct  vtkEntry
enum  DefaultModes { MIN, MAX, MID }
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the propertyy is in the domain. More...
bool IsInDomain (unsigned int idx, T val)
 Returns true if the double (val) is in the domain. More...
T GetMinimum (unsigned int idx, int &exists)
 Return a min. More...
T GetMaximum (unsigned int idx, int &exists)
 Return a max. More...
int GetResolution ()
 Returns a resolution. More...
bool GetResolutionExists ()
 Returns if a resolution is set for the domain. More...
T GetMinimum (unsigned int idx)
 Returns the minimum/maximum value, is exists, otherwise 0 is returned. More...
T GetMaximum (unsigned int idx)
unsigned int GetNumberOfEntries ()
 Returns the number of entries in the internal maxima/minima list. More...
void Update (vtkSMProperty *) override
 Update self checking the "unchecked" values of all required properties. More...
void SetAnimationValue (vtkSMProperty *property, int idx, double value) override
 Set the value of an element of a property from the animation editor. More...
DefaultModes GetDefaultMode (unsigned int index=0)
 Get the default-mode that controls how SetDefaultValues() behaves. More...
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Set the property's default value based on the domain. More...
bool GetMinimumExists (unsigned int idx)
 Returns if minimum/maximum bound is set for the domain. More...
bool GetMaximumExists (unsigned int idx)
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMRangeDomainTemplate * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
 vtkSMRangeDomainTemplate ()
 ~vtkSMRangeDomainTemplate () override
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
const std::vector< vtkEntry > & GetEntries () const
void SetEntries (const std::vector< vtkEntry > &new_value)
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
virtual void ChildSaveState (vtkPVXMLElement *domainElement)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
std::vector< DefaultModes > DefaultModeVector
DefaultModes DefaultDefaultMode
int Resolution
 Resolution is the number of steps in the values list. More...
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
template<class T>
class vtkSMRangeDomainTemplate< T >
domains that constrain a value within a min and max.
vtkSMRangeDomainTemplate represents an interval in real space (using precision based on the data-type) specified using a min and a max value. Valid XML attributes are:
* * min
* * max
* * resolution
Both min and max attributes can have one or more space space separated value arguments. Resolution expects only one value. Optionally, a Required Property may be specified (which typically is a information property) which can be used to obtain the range for the values as follows:
* <DoubleRangeDomain ...>
*    <RequiredProperties>
*      <Property name="<InfoPropName>" function="RangeInfo" />
*    </RequiredProperties>
* </DoubleRangeDomain>
vtkSMRangeDomainTemplate provides a mechanism to control how the default value for any property can be determined using the domain either the min, max or mid of the range. One can do that using the "default_mode" attribute in XML with valid values as "min", "max", "mid", or a comma separated sequence of the three e.g "min,max,min". If none is specified, "mid" is assumed. The comma-separated sequence can be used to set a different mode for each component of the property i.e. "min,max,min" means set element 0 as min, element 1 as max and element 2 and min. If the number of elements on the property is less than the number of default specified, the last value is assumed to be repeated. Thus, "min,max,min" is same as the regular expression "min,max,min(,min)*".
Definition at line 52 of file vtkSMRangeDomainTemplate.h.
template<class T >
typedef vtkSMDomain vtkSMRangeDomainTemplate< T >::Superclass
Definition at line 55 of file vtkSMRangeDomainTemplate.h.
◆ DefaultModes
template<class T >
enum vtkSMRangeDomainTemplate::DefaultModes
Enumerator
MIN
MAX
MID
Definition at line 140 of file vtkSMRangeDomainTemplate.h.
◆ vtkSMRangeDomainTemplate()
template<class T >
vtkSMRangeDomainTemplate< T >::vtkSMRangeDomainTemplate ( )
◆ ~vtkSMRangeDomainTemplate()
template<class T >
vtkSMRangeDomainTemplate< T >::~vtkSMRangeDomainTemplate ( )
template<class T >
virtual const char* vtkSMRangeDomainTemplate< T >::GetClassName ( )
template<class T >
static int vtkSMRangeDomainTemplate< T >::IsTypeOf ( const char *  type)
template<class T >
virtual int vtkSMRangeDomainTemplate< T >::IsA ( const char *  type)
template<class T >
static vtkSMRangeDomainTemplate* vtkSMRangeDomainTemplate< T >::SafeDownCast ( vtkObject *  o)
template<class T >
void vtkSMRangeDomainTemplate< T >::PrintSelf ( ostream &  os,
◆ IsInDomain() [1/2]
template<class T >
int vtkSMRangeDomainTemplate< T >::IsInDomain ( vtkSMProperty *  property)
override
If all vector values are in the domain, it returns 1. It returns 0 otherwise. A value is in the domain if it is between (min, max).
◆ IsInDomain() [2/2]
template<class T >
bool vtkSMRangeDomainTemplate< T >::IsInDomain ( unsigned int  idx,
T  val
If value is in domain, it's index is return in idx. A value is in the domain if it is between (min, max)
◆ GetMinimum() [1/2]
template<class T >
T vtkSMRangeDomainTemplate< T >::GetMinimum ( unsigned int  idx,
int &  exists
Return a min.
value if it exists. If the min. exists exists is set to 1. Otherwise, it is set to 0. An unspecified min. is equivalent to -inf
◆ GetMaximum() [1/2]
template<class T >
T vtkSMRangeDomainTemplate< T >::GetMaximum ( unsigned int  idx,
int &  exists
Return a max.
value if it exists. If the max. exists exists is set to 1. Otherwise, it is set to 0. An unspecified max. is equivalent to +inf
◆ GetResolution()
template<class T >
int vtkSMRangeDomainTemplate< T >::GetResolution ( )
Default is -1.
◆ GetMinimumExists()
template<class T >
bool vtkSMRangeDomainTemplate< T >::GetMinimumExists ( unsigned int  idx)
◆ GetMaximumExists()
template<class T >
bool vtkSMRangeDomainTemplate< T >::GetMaximumExists ( unsigned int  idx)
◆ GetResolutionExists()
template<class T >
bool vtkSMRangeDomainTemplate< T >::GetResolutionExists ( )
◆ GetMinimum() [2/2]
template<class T >
T vtkSMRangeDomainTemplate< T >::GetMinimum ( unsigned int  idx)
inline
Use GetMaximumExists() GetMaximumExists() to make sure that the bound is set.
Definition at line 110 of file vtkSMRangeDomainTemplate.h.
◆ GetMaximum() [2/2]
template<class T >
T vtkSMRangeDomainTemplate< T >::GetMaximum ( unsigned int  idx)
inline
Definition at line 115 of file vtkSMRangeDomainTemplate.h.
◆ GetNumberOfEntries()
template<class T >
unsigned int vtkSMRangeDomainTemplate< T >::GetNumberOfEntries ( )
No maxima/minima exists beyond this index. Maxima/minima below this number may or may not exist.
◆ Update()
template<class T >
void vtkSMRangeDomainTemplate< T >::Update ( vtkSMProperty *  )
◆ SetAnimationValue()
template<class T >
void vtkSMRangeDomainTemplate< T >::SetAnimationValue ( vtkSMProperty *  property,
int  idx,
double  value
override
◆ GetDefaultMode()
template<class T >
DefaultModes vtkSMRangeDomainTemplate< T >::GetDefaultMode ( unsigned int  index = 0)
◆ SetDefaultValues()
template<class T >
int vtkSMRangeDomainTemplate< T >::SetDefaultValues ( vtkSMProperty *  ,
override
How the value is determined using the range is controlled by DefaultMode.
◆ ReadXMLAttributes()
template<class T >
int vtkSMRangeDomainTemplate< T >::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ GetEntries()
template<class T >
const std::vector<vtkEntry>& vtkSMRangeDomainTemplate< T >::GetEntries ( ) const
inlineprotected
Definition at line 199 of file vtkSMRangeDomainTemplate.h.
◆ SetEntries()
template<class T >
void vtkSMRangeDomainTemplate< T >::SetEntries ( const std::vector< vtkEntry > &  new_value)
inlineprotected
Definition at line 200 of file vtkSMRangeDomainTemplate.h.
◆ DefaultModeVector
template<class T >
std::vector<DefaultModes> vtkSMRangeDomainTemplate< T >::DefaultModeVector
Definition at line 211 of file vtkSMRangeDomainTemplate.h.
◆ DefaultDefaultMode
template<class T >
DefaultModes vtkSMRangeDomainTemplate< T >::DefaultDefaultMode
Definition at line 212 of file vtkSMRangeDomainTemplate.h.
◆ Resolution
template<class T >
int vtkSMRangeDomainTemplate< T >::Resolution
Definition at line 217 of file vtkSMRangeDomainTemplate.h.
