vtkSMEnumerationDomain Class Reference
list of integers with associated strings More...
#include <vtkSMEnumerationDomain.h>
Inheritance diagram for vtkSMEnumerationDomain:
Collaboration diagram for vtkSMEnumerationDomain:
typedef vtkSMDomain Superclass
- Public Types inherited from vtkSMDomain
enum  IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 }
 Return values for IsInDomain calls. More...
int IsInDomain (vtkSMProperty *property) override
 Returns true if the value of the property is in the domain. More...
int IsInDomain (int val, unsigned int &idx)
 Returns true if the int is in the domain. More...
unsigned int GetNumberOfEntries ()
 Returns the number of entries in the enumeration. More...
int GetEntryValue (unsigned int idx)
 Returns the integer value of an enumeration entry. More...
const char * GetEntryText (unsigned int idx)
 Returns the descriptive string of an enumeration entry. More...
const char * GetEntryTextForValue (int value)
 Returns the text for an enumeration value. More...
int HasEntryText (const char *text)
 Return 1 is the text is present in the enumeration, otherwise 0. More...
int GetEntryValueForText (const char *text)
 Get the value for an enumeration text. More...
int GetEntryValue (const char *text, int &valid)
 Given an entry text, return the integer value. More...
const char * GetInfoText (unsigned int idx)
 Returns the info text for an enumeration entry. More...
void AddEntry (const char *text, int value, const char *info=nullptr)
 Add a new enumeration entry. More...
void RemoveAllEntries ()
 Clear all entries. More...
void Update (vtkSMProperty *property) override
 Update self based on the "unchecked" values of all required properties. More...
- Public Member Functions inherited from vtkSMDomain
virtual int IsInDomain (vtkSMProperty *vtkNotUsed(property))
 Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More...
virtual void SetAnimationValue (vtkSMProperty *, int vtkNotUsed(index), double vtkNotUsed(value))
 Set the value of an element of a property from the animation editor. More...
virtual int SetDefaultValues (vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
 A vtkSMProperty is often defined with a default value in the XML itself. More...
vtkSMProperty * GetProperty ()
 Provides access to the vtkSMProperty on which this domain is hooked up. More...
virtual unsigned int GetNumberOfInputConnections (const char *function)
 Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More...
vtkSMProperty * GetRequiredProperty (const char *function)
 Returns a given required property of the given function. More...
virtual char * GetXMLName ()
virtual bool GetIsOptional ()
 When the IsOptional flag is set, IsInDomain() always returns true. More...
virtual vtkPVDataInformation * GetInputDataInformation (const char *function, unsigned int index=0)
 Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More...
virtual vtkPVDataInformation * GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0)
virtual void SetSession (vtkSMSession *)
static vtkSMEnumerationDomain * New ()
static vtkSMEnumerationDomain * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMDomain
static vtkSMDomain * New ()
static vtkSMDomain * SafeDownCast (vtkObject *o)
static vtkSMObject * New ()
int ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override
void ChildSaveState (vtkPVXMLElement *domainElement) override
 Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More...
- Protected Member Functions inherited from vtkSMDomain
 vtkSMDomain ()
 ~vtkSMDomain () override
virtual int LoadState (vtkPVXMLElement *vtkNotUsed(domainElement), vtkSMProxyLocator *vtkNotUsed(loader))
 Load the state of the domain from the XML. More...
void RemoveRequiredProperty (vtkSMProperty *prop)
 Remove the given property from the required properties list. More...
void AddRequiredProperty (vtkSMProperty *prop, const char *function)
 Add a new required property to this domain. More...
void DomainModified ()
 Invokes DomainModifiedEvent. More...
void InvokeModified ()
unsigned int GetNumberOfRequiredProperties ()
 Gets the number of required properties added. More...
void SetProperty (vtkSMProperty *)
 Set the domain's property. More...
void SaveState (vtkPVXMLElement *parent, const char *uid)
virtual void SetIsOptional (bool)
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
int SetDefaultValues (vtkSMProperty *, bool use_unchecked_values) override
 Overridden to ensure that the property's default value is valid for the enumeration, if not it will be set to the first enumeration value. More...
 vtkSMEnumerationDomain ()
 ~vtkSMEnumerationDomain () override
- Protected Attributes inherited from vtkSMDomain
char * XMLName
bool IsOptional
vtkSMDomainInternals * Internals
vtkSMEnumerationDomain represents an enumeration of integer values with associated descriptive strings.
A typical enumeration domain is described as follows in the servermanager configuration xmls.
<IntVectorProperty ...>
<EnumerationDomain name="enum">
<Entry text="PNG" value="0"/>
<Entry text="JPEG" value="1"/>
</EnumerationDomain>
</IntVectorProperty>
Where, value is the integral value to use to set the element on the property and text is the descriptive text used in UI and Python script.
Starting with ParaView 5.5, the info attribute is supported on an Entry The value is an additional qualifier for the entry that used in UI to explain the item e.g.
<IntVectorProperty name="Quality">
<Entry text="one" value="0" info="no compression" />
<Entry text="ten" value="10" info="max compression" />
</IntVectorProperty>*
If info is specified and non-empty, then the UI will show that text in the combo-box rendered in addition to the text. info has no effect on the Python API i.e.
# either of the following is acceptable, note how `info` has no effect.
writer.Quality = "ten"
# or
writer.Quality = 10
Definition at line 67 of file vtkSMEnumerationDomain.h.
Definition at line 71 of file vtkSMEnumerationDomain.h.
◆ vtkSMEnumerationDomain()
vtkSMEnumerationDomain::vtkSMEnumerationDomain ( )
◆ ~vtkSMEnumerationDomain()
vtkSMEnumerationDomain::~vtkSMEnumerationDomain ( )
static vtkSMEnumerationDomain* vtkSMEnumerationDomain::New ( )
virtual const char* vtkSMEnumerationDomain::GetClassName ( )
Reimplemented in vtkSMFieldDataDomain, and vtkSMNumberOfComponentsDomain.
static int vtkSMEnumerationDomain::IsTypeOf ( const char *  type)
virtual int vtkSMEnumerationDomain::IsA ( const char *  type)
static vtkSMEnumerationDomain* vtkSMEnumerationDomain::SafeDownCast ( vtkObject *  o)
void vtkSMEnumerationDomain::PrintSelf ( ostream &  os,
◆ IsInDomain() [1/2]
int vtkSMEnumerationDomain::IsInDomain ( vtkSMProperty *  property)
override
The property has to be a vtkSMIntVectorProperty. If all vector values are in the domain, it returns 1. It returns 0 otherwise.
◆ IsInDomain() [2/2]
int vtkSMEnumerationDomain::IsInDomain ( int  val,
unsigned int &  idx
If value is in domain, it's index is return in idx.
◆ GetNumberOfEntries()
unsigned int vtkSMEnumerationDomain::GetNumberOfEntries ( )
◆ GetEntryValue() [1/2]
int vtkSMEnumerationDomain::GetEntryValue ( unsigned int  idx)
◆ GetEntryText()
const char* vtkSMEnumerationDomain::GetEntryText ( unsigned int  idx)
◆ GetEntryTextForValue()
const char* vtkSMEnumerationDomain::GetEntryTextForValue ( int  value)
◆ HasEntryText()
int vtkSMEnumerationDomain::HasEntryText ( const char *  text)
◆ GetEntryValueForText()
int vtkSMEnumerationDomain::GetEntryValueForText ( const char *  text)
The return value is valid only is HasEntryText() returns 1.
◆ GetEntryValue() [2/2]
int vtkSMEnumerationDomain::GetEntryValue ( const char *  text,
int &  valid
Valid is set to 1 if text is defined, otherwise 0. If valid=0, return value is undefined.
◆ GetInfoText()
const char* vtkSMEnumerationDomain::GetInfoText ( unsigned int  idx)
Parameters
[in]idx- index for the entry (not to confused with value).
Returns
info-text, if non-empty else nullptr.
◆ AddEntry()
void vtkSMEnumerationDomain::AddEntry ( const char *  text,
int  value,
const char *  info = nullptr
text cannot be null.
◆ RemoveAllEntries()
void vtkSMEnumerationDomain::RemoveAllEntries ( )
Clear all entries.
◆ Update()
void vtkSMEnumerationDomain::Update ( vtkSMProperty *  property)
◆ SetDefaultValues()
int vtkSMEnumerationDomain::SetDefaultValues ( vtkSMProperty *  ,
override
◆ ReadXMLAttributes()
int vtkSMEnumerationDomain::ReadXMLAttributes ( vtkSMProperty *  prop,
vtkPVXMLElement *  element
overrideprotectedvirtual
◆ ChildSaveState()
void vtkSMEnumerationDomain::ChildSaveState ( vtkPVXMLElement *  domainElement)
The newly created element will also be added to the parent element as a child node. Subclasses can override ChildSaveState() method to fill it up with subclass specific values.
