vtkPVPluginLoader Class Reference
Used to load ParaView plugins. More...
#include <vtkPVPluginLoader.h>
Inheritance diagram for vtkPVPluginLoader:
Collaboration diagram for vtkPVPluginLoader:
bool LoadPluginByName (const char *name, bool acceptDelayed=true)
 Tries to the load the plugin by name using tracked plugins. More...
bool LoadPlugin (const char *filename)
 Tries to the load the plugin given the path to the plugin file. More...
bool LoadPluginSilently (const char *filename)
bool LoadDelayedLoadPlugin (const std::string &name, const std::vector< std::string > &xmls, const std::string &filename)
 Load a delayed load plugin with provided name, XMLs and an actual plugin filename The actual loading will take place the first time a VTK object for a XML proxy needs to be created. More...
void LoadPluginsFromPluginSearchPath ()
 Loads all plugins under the directories mentioned in the SearchPaths. More...
void LoadPluginsFromPluginConfigFile ()
 Use PV_PLUGIN_CONFILE_FILE xml file to load specified plugins It can contain path to multiples xml pluginc config files sperated by env separator. More...
void LoadPluginsFromPath (const char *path)
 Loads all plugin libraries at a path. More...
void LoadPluginConfigurationXMLFromString (const char *xmlcontents)
 Simply forwards the call to vtkPVPluginTracker to load configuration xml. More...
void LoadPluginConfigurationXML (const char *configurationFile)
virtual char * GetFileName ()
 Returns the full filename for the plugin attempted to load most recently using LoadPlugin(). More...
virtual char * GetPluginName ()
 Get the plugin name. More...
virtual char * GetPluginVersion ()
 Get the plugin version string. More...
virtual char * GetErrorString ()
 Get the error string if the plugin failed to load. More...
virtual char * GetSearchPaths ()
 Get a string of standard search paths (path1;path2;path3) search paths are based on PV_PLUGIN_PATH, plugin dir relative to executable. More...
virtual bool GetLoaded ()
 Returns the status of most recent LoadPlugin call. More...
static vtkPVPluginLoader * New ()
static vtkPVPluginLoader * SafeDownCast (vtkObject *o)
static void PluginLibraryUnloaded (const char *pluginname)
 Internal method used in pqParaViewPlugin.cxx.in to tell the vtkPVPluginLoader that a library was unloaded so it doesn't try to unload it again. More...
 vtkPVPluginLoader ()
 ~vtkPVPluginLoader () override
bool LoadPluginInternal (const char *filename, bool no_errors)
bool LoadPluginInternal (vtkPVPlugin *plugin)
 Called by LoadPluginInternal() to do the final steps in loading of a plugin. More...
bool IsLoaded (const char *filename, bool acceptDelayed=false)
 Return true if a plugin pointing provided filename is already loaded, return false otherwise. More...
virtual void SetErrorString (const char *)
virtual void SetPluginName (const char *)
virtual void SetPluginVersion (const char *)
virtual void SetSearchPaths (const char *)
char * ErrorString
char * PluginName
char * PluginVersion
char * FileName
char * SearchPaths
bool Loaded
using PluginLoaderCallback = std::function< bool(const char *)>
static int RegisterLoadPluginCallback (PluginLoaderCallback callback)
static void UnregisterLoadPluginCallback (int id)
vtkPVPluginLoader can be used to load plugins for ParaView. vtkPVPluginLoader loads the plugin on the local process.
vtkPVPluginLoader logs plugin related messages using at PARAVIEW_LOG_PLUGIN_VERBOSITY level. See vtkPVLogger::SetPluginVerbosity for information on using environment variables to override or elevate the verbosity level.
This class only needed when loading plugins from shared libraries dynamically. For statically importing plugins, one directly uses PV_PLUGIN_IMPORT() macro defined in vtkPVPlugin.h.
Definition at line 30 of file vtkPVPluginLoader.h.
Definition at line 34 of file vtkPVPluginLoader.h.
◆ PluginLoaderCallback
Definition at line 143 of file vtkPVPluginLoader.h.
◆ vtkPVPluginLoader()
vtkPVPluginLoader::vtkPVPluginLoader ( )
◆ ~vtkPVPluginLoader()
vtkPVPluginLoader::~vtkPVPluginLoader ( )
static vtkPVPluginLoader* vtkPVPluginLoader::New ( )
virtual const char* vtkPVPluginLoader::GetClassName ( )
static int vtkPVPluginLoader::IsTypeOf ( const char *  type)
virtual int vtkPVPluginLoader::IsA ( const char *  type)
static vtkPVPluginLoader* vtkPVPluginLoader::SafeDownCast ( vtkObject *  o)
void vtkPVPluginLoader::PrintSelf ( ostream &  os,
◆ LoadPluginByName()
bool vtkPVPluginLoader::LoadPluginByName ( const char *  name,
bool  acceptDelayed = true
◆ LoadPlugin()
bool vtkPVPluginLoader::LoadPlugin ( const char *  filename)
inline
Definition at line 45 of file vtkPVPluginLoader.h.
◆ LoadPluginSilently()
bool vtkPVPluginLoader::LoadPluginSilently ( const char *  filename)
inline
Definition at line 46 of file vtkPVPluginLoader.h.
◆ LoadDelayedLoadPlugin()
bool vtkPVPluginLoader::LoadDelayedLoadPlugin ( const std::string &  name,
const std::vector< std::string > &  xmls,
const std::string &  filename
◆ LoadPluginConfigurationXMLFromString()
void vtkPVPluginLoader::LoadPluginConfigurationXMLFromString ( const char *  xmlcontents)
◆ LoadPluginConfigurationXML()
void vtkPVPluginLoader::LoadPluginConfigurationXML ( const char *  configurationFile)
◆ LoadPluginsFromPluginSearchPath()
void vtkPVPluginLoader::LoadPluginsFromPluginSearchPath ( )
◆ LoadPluginsFromPluginConfigFile()
void vtkPVPluginLoader::LoadPluginsFromPluginConfigFile ( )
It allow user to fine pick which plugins to load, instead of using PV_PLUGIN_PATH the format a xml plugin file should be the following :
<?xml version="1.0"?>
<Plugins>
<Plugin name="MyPlugin" filename="absolute/path/to/libMyPlugin.so"/>
</Plugins>
◆ LoadPluginsFromPath()
void vtkPVPluginLoader::LoadPluginsFromPath ( const char *  path)
◆ GetFileName()
virtual char* vtkPVPluginLoader::GetFileName ( )
◆ GetPluginName()
virtual char* vtkPVPluginLoader::GetPluginName ( )
This returns a valid name only after the plugin has been loaded.
◆ GetPluginVersion()
virtual char* vtkPVPluginLoader::GetPluginVersion ( )
This returns a valid version string only after the plugin has been loaded.
◆ GetErrorString()
virtual char* vtkPVPluginLoader::GetErrorString ( )
Returns nullptr if the plugin was loaded successfully.
◆ GetSearchPaths()
virtual char* vtkPVPluginLoader::GetSearchPaths ( )
◆ GetLoaded()
virtual bool vtkPVPluginLoader::GetLoaded ( )
◆ RegisterLoadPluginCallback()
static int vtkPVPluginLoader::RegisterLoadPluginCallback ( PluginLoaderCallback  callback)
◆ UnregisterLoadPluginCallback()
static void vtkPVPluginLoader::UnregisterLoadPluginCallback ( int  id)
◆ PluginLibraryUnloaded()
static void vtkPVPluginLoader::PluginLibraryUnloaded ( const char *  pluginname)
◆ LoadPluginInternal() [1/2]
bool vtkPVPluginLoader::LoadPluginInternal ( const char *  filename,
bool  no_errors
◆ LoadPluginInternal() [2/2]
bool vtkPVPluginLoader::LoadPluginInternal ( vtkPVPlugin *  plugin)
◆ IsLoaded()
bool vtkPVPluginLoader::IsLoaded ( const char *  filename,
bool  acceptDelayed = false
Delayed load plugin are considered not loaded until they actually are as standard plugins.
◆ SetErrorString()
virtual void vtkPVPluginLoader::SetErrorString ( const char *  )
protectedvirtual
◆ SetPluginName()
virtual void vtkPVPluginLoader::SetPluginName ( const char *  )
protectedvirtual
◆ SetPluginVersion()
virtual void vtkPVPluginLoader::SetPluginVersion ( const char *  )
protectedvirtual
◆ SetFileName()
virtual void vtkPVPluginLoader::SetFileName ( const char *  )
protectedvirtual
◆ SetSearchPaths()
virtual void vtkPVPluginLoader::SetSearchPaths ( const char *  )
protectedvirtual
◆ ErrorString
char* vtkPVPluginLoader::ErrorString
Definition at line 177 of file vtkPVPluginLoader.h.
◆ PluginName
char* vtkPVPluginLoader::PluginName
Definition at line 180 of file vtkPVPluginLoader.h.
◆ PluginVersion
char* vtkPVPluginLoader::PluginVersion
Definition at line 181 of file vtkPVPluginLoader.h.
◆ FileName
char* vtkPVPluginLoader::FileName
Definition at line 182 of file vtkPVPluginLoader.h.
◆ SearchPaths
char* vtkPVPluginLoader::SearchPaths
Definition at line 183 of file vtkPVPluginLoader.h.
◆ Loaded
bool vtkPVPluginLoader::Loaded
Definition at line 184 of file vtkPVPluginLoader.h.
